I have tried both YAML and the Visual Editor in the frontend but I just get errors when I try and run the automation, if I remove any !secret then they work fine.
I would like to do everything in the frontend if possible, like this ?
If my understanding is correct, using secrets.yaml only hides the values in the textual representation of files that !secret is used. Once the file is compiled to be ran, the secrets are slotted in in place of every !secret; secrets are not variables that are checked and passed on the fly. Even if you got this working, it would be like storing SSNs in the HTML of a website, and no different than storing the code in there directly. However, a big difference is that your dashboard is hopefully private to just you.
If you are really expecting prying eyes and have found a way to use secrets in action sequences, why not just create scripts for those specific service calls and call those scripts instead of the service calls directly? However, anybody who has access to your UI is going to have access to your scripts.
I don’t want to store the same alarm code in multiple different files (dupliction), and if I post any code to a website, github etc I don’t want the secret to be displayed - those are the reasons for me using secrets.
My question purely relates to the frontend, but after quite a bit of searching I’m pretty sure the frontend just doesn’t support them.
