Create condition based on 2 tirggers, but based on time of second trigger
Good day,
I have an automation here, that announces when my clothes washing machine is done. It also provides an estimated time to finish.
two triggers are used:
washing_started
washing_ended
How can I create a condition that says to ignore the washing_ended trigger if the washing_started trigger has not started in the last 5 minutes?
I’m hoping this will deal with the random energy usage spikes that my washing machine does when its NOT in use.
Personally, I would create a binary sensor for “Washer Running” and use that as your on/off trigger for your automation. You can build a delay into that. Makes for a handy sensor to display on your dashboard too.
template:
  - binary_sensor:
      - name: "Washer Running"
        unique_id: washer_running
        device_class: running
        delay_on: 60  # set to longer than your power spikes
        state: "{{ states('sensor.smart_switch_7_electric_consumption_w')|float(-1) > 3.1 }}"
Change your automation trigger to
    - platform: state
      entity_id: binary_sensor.washer_running
      not_from:
        - unknown
        - unavailable
Then change your if / then / else.
  - if:
      - condition: state
        state: "on"
    then:
Hey @jazzyisj this is pretty clever, actually, let the binary_sensor delay or “absorb” the 10-15 second spikes! like a hysteresis which is exactly what I’m looking for. I’ll give this shot.
Once I create the sensor with a 20 second delay:
template:
  - binary_sensor:
        delay_on: 20  # set to longer than your power spikes
Here’s the modified automation. If I did it correctly, it should not affect the existing timing system that was in place, and still work as normal.
alias: Washing Machine Status
description: For Washing Machine notification system
  - platform: state
    to: on
  - platform: state
    to: off
condition:
  - condition: template
    value_template: "{{ trigger.from_state.state not in ['unknown', 'unavailable'] }}"
  - if:
      - condition: trigger
        alias: Washing Machine Started
    then:
      - service: zwave_js.set_config_parameter
          parameter: "21"
          value: "0"
          device_id: 4d008806cd3f0815b7c45579c71444de
          parameter: "23"
          value: "120"
      - service: input_datetime.set_datetime
          datetime: "{{ now() }}"
          entity_id: input_datetime.washing_machine_started
          datetime: >-
            {{ (now().timestamp() +
            states('input_number.washing_machine_expected_runtime') | float(0))
            | timestamp_local() }}
          entity_id: input_datetime.washing_machine_expected_time_to_stop
    else:
          entity_id: input_datetime.washing_machine_stopped
      - service: input_number.set_value
          value: >-
            {{ (as_timestamp(states('input_datetime.washing_machine_stopped')) -
            as_timestamp(states('input_datetime.washing_machine_started'))) |
            float(0) }}
          entity_id: input_number.washing_machine_expected_runtime
          parameter: "21"
          value: "1"
          parameter: "23"
          value: "0"
      - service: notify.mobile_app_sony_xperia_zx1
          message: Washing machine is done!
          title: Washing Machine Status
      - service: notify.mobile_app_iphone
      - service: tts.cloud_say
          entity_id: media_player.fire_tablet
          message: The washing machine is done.
mode: single
You can still clean that up some. Combine the triggers. If you specify not_from: unknown, unavailable you don’t need the condition. You can use the binary sensor for your if: condition, then you don’t need a trigger id.
  - platform: state
    to:
      - "on"
      - "off"
    not_from:
      - unknown
      - unavailable
  - if:
      - condition: state
        state: "on"
    then:
      - < do your stuff here for washer running on here>
    else:
      - < do your stuff here for washer running off here>
mode: single
Don’t forget to mark your post as solved!
Brilliant! thank you vert much!
Anthony
