Create curtain helper to see the current state
i have some curtains from Somfy, where i want to read out the state, which is not possible with the RTS module.
Now i have tried to make a helper, but i can only use a switch, which is on or off.
How can use another switch where i have the option between open/close/favorite position?
Here is an open source module that will let you do all of that.
