I would like to create a dimmer from IR commands that are send via the broadlink RM pro.
When i do a long press on my IR remote, the lights will dim.
I created 4 scripts based on IR codes from my remote: on/off/dim+/dim-. These scripts work fine when i run them in HA but i would like to implement these 4 scripts into 1 dimmer.
When i press on the dim+ script 5 times i noticed my lamps are at max brightness so one press is about 20%.
Based on that is would like to make a dimmer that runs the following scripts:
if slider is at 20%, run script dim+
if slider is at 40%, run script dim+ 2x
if slider is at 60%, run script dim+ 3x
if slider is at 80%, run script dim+ 4x
if slider is at 100% run script on
if slider goes down 20%, run script -
Because i want to use the dimmer in homekit. i would like to create a template.light but i have not yet acquired the skills how implement the scripts into the set_level variable.
If you guys have other suggestions how to create a dimmer from a switchs based on IR commands, i am happy to hear them!
i managed to get my dimmer working partially.
when i set slider to value 51, 102, 153 etc, lights react accordingly.
however. when i but my slider down, nothing happens.
I realize this is almost 2 years old but did you ever get this working?
I’m trying to do the same. So far I have scripts which replicate all the remote buttons (on/off/dim/bright/warm/cool) but wish to template these into a light.
