Is it possible to have a switch read high/low instead of off/on? I integrating a Hot Tub and it has a heating mode switch but the on/off doesn’t make immediate sense.
If you build a binary_sensor
on your switch, you can assign the class heat
(or cold
) and you’ll see
heat:
on
means hot,off
means normal -
cold:
on
means cold,off
means normal
Okay, so I’d then need to create a virtual switch to display in a card?
The way I’d do is like so:
Create a template binary_sensor, based on your switch
- binary_sensor:
- name: hottub
state: >
{{ states("switch.hottub") }}
device_class: heat
And use it into the card.
But it will not activate the switch for you, you’ll have to write something like an automation to turn the real switch on/off
I know that there is something called Template Switch
but can’t still figure out what it is used for.
