Create/Import entity values (for the past)
I’m using HA for Energy Counter recording since 2 Month… in the past I used an Excel table.
|7.12.21|19.1.21|20.1.21|24.2.21|25.3.21|
|8453 |8702 |8706 |8838 |8853 |
So… It would be great if there was a method to import the values from table into HA.
I recently got this, not tested it myself …the second one is only for a specific data-source though
ldotlopez/ha-historical-sensor: Historical sensors for Home Assistant (github.com)
chocomega/statistics_importer: This Python script retrieves statistics from MyElectricalData’s cache database and imports them into Home Assistant via the WebSocket API. (github.com)
THX - I’ll try it :wink:
And there is also an option via spook … but reading the disclaimers, I also believe this may make your system unspported (It works fine on my dev instance though)
frenck/spook: Spook :ghost: Not your homie (github.com)
Unfortunately all of this solutions can’t solve my problem. I thought it would be possible to add past values to an existing entity. But Homeassistant has a different opinion :wink: I don’t understand why import hasn’t been available as a standard feature for a long time.
I agree to have not tested either fo them but they do promise to load historical data…address them directly I would say
