Device Name is “Front door Doorbell”. This is a bad name on my part but can be ignored for this issue
The trigger has some poorly describing labels, such as “Motion started detecting motion”. It should be renamed to “Motion Detected” or “Started detecting motion”
“Person turned on”, based on documentation actually means something like “Person detected”. “Person turned off”, means something like “Person no longer detected”
“Visitor turned on” based on documentation means the doorbell button was pressed, or maybe the sound started playing.
Numerous other of these have similar labels ending with “turned on” or “turned off”. At the very least “Visitor detected [event started]” and “Visitor detected[event ended]” would be more user friendly
If that 's the way you’d like to see it, just add a name to the binary motion sensor and you’ll get this…
Motion is the standard name added by the integration.
It needs to added here.
The sensor names are spit for a reason. You’ll get a bunch if entities with the same name so I’d keep the entity ids the same if you go that route.
If you name the sensors to Motion Sensor, Person Sensor, Vehicle Sensor you get a clearer picture
This is because the sensors are binary.
Just a heads up, you can vote for your own FR
Ahh, okay. I guess that makes sense.
Why is this so? Is there a naming convention that I’m not following that would make this default behavior make more sense? As of now it would just be “>name< Motion started detecting motion”, which seems non-intuitive to me.
The Motion Sensor is binary but it uses “started detecting motion” instead of “turned on”. Is changing that label or text possible somewhere? It feels like an oversight to do it for motion but not person, vehicle or visitor
