Hi all,
I have an old fashioned energy meter. I’ve used this great tutorial to get a ESP32 camera to take pictures every 5 minutes to ‘read’ the energy meter (Welcome - AI on the Edge Device) and deliver the numbers back through MQTT (sensor.electra_meter_value in the code below). That all works fine. Usually the meter increases, but on an sunny day my solar panels return power to the grid and the meter value decreases.
Now I’m trying to get a sensor which determines how much energy I give back to the grid. Basically I want to make a sensor that only calculates the amount the meter decreases to add to the energy dashboard.
I’ve used this forum link to make the two utility meters (How can I configure the energy dashboard to understand my net electric meter? - #24 by wildekek) and tried to add a new sensor that inverses the meter readings.
This is the code that I have in the configuration.yaml
platform: template
sensors:
grid_energy_inverted:
value_template: "{{ 'sensor.electra_meter_value' | multiply(-1) | float }}"
unique_id: grid_energy_inverted_calc
utility_meter:
grid_energy_consumed:
name: "Grid Energy Consumed"
unique_id: grid_energy_consumed
source: sensor.electra_meter_value
delta_values: false
net_consumption: false
periodically_resetting: false
grid_energy_produced:
name: "Grid Energy Produced"
unique_id: grid_energy_produced
source: sensor.grid_energy_inverted
delta_values: false
I’m getting two errors in the logs:
TemplateError('ValueError: Template error: multiply got invalid input 'sensor.electra_meter_value' when rendering template '{{ 'sensor.electra_meter_value' | multiply(-1) | float }}' but no default was specified') while processing template 'Template<template=({{ 'sensor.electra_meter_value' | multiply(-1) | float }}) renders=4>' for attribute '_attr_native_value' in entity 'sensor.grid_energy_inverted'`
And the other log error:
Logger: homeassistant.helpers.event
Source: helpers/template.py:587
First occurred: 13:42:43 (1 occurrences)
Last logged: 13:42:43
Error while processing template: Template<template=({{ 'sensor.electra_meter_value' | multiply(-1) | float }}) renders=2>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1880, in multiply
return float(value) * amount
ValueError: could not convert string to float: 'sensor.electra_meter_value'
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 585, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)`
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2600, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 1301, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 936, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1884, in multiply
raise_no_default("multiply", value)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1849, in raise_no_default
raise ValueError(
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 713, in async_render_to_info
render_info._result = self.async_render(
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 587, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: ValueError: Template error: multiply got invalid input 'sensor.electra_meter_value' when rendering template '{{ 'sensor.electra_meter_value' | multiply(-1) | float }}' but no default was specified`
What’s going wrong here? Much appreciated for your time!
