While creating scripts from the UI is really easy, when it comes to lighting and especially lights that have dimming + colour changing, I find it really hard to create a script with the correct balance of hue and brightness by just blindly creating it from the scripts section and then running it to see if its what I really wanted.
What would be really good would be if the lights could be set to the required levels, colours etc from a dashboard type UI which allows you to see the changes you are making to each entity/ device in real time and then have the ability to export the current states as a script.
In addition to being really helpful in precisely fine tuning scripts, this would also simplify the creation of scripts for users who arent even tech savvy enough to set it up from the scripts section. Just set states and export to create a new script/ scene.
