I have some sensor data (numerical) that i display in a vertical-stack chart, that is working great!
Beside that, I want to display the same data also on a vertical-stack chart, but simplified. (and to be compareable to another set of data, outside home assistant)
Therefore de chart should only show numbers from 1-6, depending in which boundaries the real value is. For example the real value is between …
0-100 → output value 1
100-250 → output value 2
250-550 → output value 3
550-700 → output value 4
700-9999 → output value 5
how should I go about this? Is it possible to create additional sensor data that is based on the real sensor?
Thank you for your magic. Could it be, that is will be saved as string instead of an integer? Because I am not able to display the data in a line chart. (I used the first template.)
//edit:
the issue of not beeing able to show the data in a line chart was because I had no unit defined for the entities.
In addition to this, is there a good documentation of how home assistant is using this coding blocks? I know it is some form of phyton, but I have never seen this piping like behavour which i only know of linux shells like bash.
I could maybe also make use of this. I do not know phyton very well, but I am familiar with other high level languages.
