I receive energy data from my P1 cable in the form of a json. This is the part of the output of said data, but seperated monthly:
"CONSUMPTION_DELTA_KWH": 73.28300000000135,
"CONSUMPTION_GAS_DELTA_M3": 15.736000000000104,
"CONSUMPTION_GAS_M3": 1749.255,
"CONSUMPTION_KWH_HIGH": 3458.681,
"CONSUMPTION_KWH_LOW": 4372.907,
"PRODUCTION_DELTA_KWH": 2.510000000000218,
"PRODUCTION_KWH_HIGH": 4725.154,
"PRODUCTION_KWH_LOW": 1968.589,
"TIMESTAMP_UTC": 1672527600,
"TIMESTAMP_lOCAL": "2023-01-01 00:00:00"
"CONSUMPTION_DELTA_KWH": 289.6369999999947,
"CONSUMPTION_GAS_DELTA_M3": 125.817,
"CONSUMPTION_GAS_M3": 1733.519,
"CONSUMPTION_KWH_HIGH": 3412.274,
"CONSUMPTION_KWH_LOW": 4345.865,
"PRODUCTION_DELTA_KWH": 12.928000000000011,
"PRODUCTION_KWH_HIGH": 4723.441,
"PRODUCTION_KWH_LOW": 1967.792,
"TIMESTAMP_UTC": 1669849200,
"TIMESTAMP_lOCAL": "2022-12-01 00:00:00"
How can I fill a sensor so, for instance, the “CONSUMPTION_GAS_M3” can be used in charts etc? I can create a sensor per month, but that creates 12 extra sensors and is unusable in charts. I’m sure there is a simpler way to achieve this.
