Create sensor that triggers once counter increments
I’ve got a sensor that counts the number of people who are home.
 people_at_home:
   entity_id:
     - person.john_doe
     - person.jane_doe
     - person.fred_doe
   friendly_name: "How many people are at home?"
   value_template: >-
     {{ states.person | selectattr('state', 'eq', 'home') | list | count | int }}
Now I would like to trigger a sensor if the number increases only (no decrease). I’m happy for this sensor to be as simple as True/False.
Any ideas how I can do this.?
Do you really want a [binary_]sensor that is true if the value of sensor.people_at_home increases? Or are you just thinking of using that to trigger an automation?
FWIW, I also have a sensor that indicates the number of people that are home, and I use it directly in two automations, one that changes my “home mode” input_select to Away:
  - alias: Home Mode - Leaving
      platform: numeric_state
      entity_id: sensor.n_people_home
      below: 1
    condition:
      condition: state
      entity_id: input_select.home_mode
      state: Home
      service: input_select.select_option
        option: Away
and another that changes it to Home:
  - alias: Home Mode - Arriving
      platform: state
    condition:
      condition: template
      value_template: >
        {{ trigger.to_state.state|int > trigger.from_state.state|int }}
        option: Home
BTW, the reason for the condition in the first automation is that input_select.home_mode has more options than Home & Away, and I only want to change it to Away if it is currently Home.
Thanks, that is exactly what I want!!! It works well.
