Dear all,
I am new to HA and also to Python. Python is not the problem at the moment.
I try to create my own integration.
So far, I am on a good way, but now I am stuck.
The easiest way would be, if HA would display HTML from a sensor value in a card. I mean pure HTML, not this Markdown card. In this case, I can format it in the sensor.py and all is fine. But as far as I know this is no feature from HA. I also do not want template scripting in the configuration.yaml because I want to share the integration later and this will lead to more problems than without.
Background is, I want to create a “Train Display” for my local train station.
So far I get the data from the API and have them available in my integration.
My problem is, that I am stuck with creating the attributes for the sensor.
The attributes don’t show up under Stats – Attributes. Only friendly_name is there
This is my code. I reduced non important parts like the function to call the API
"""Platform for sensor integration."""
from __future__ import annotations
import voluptuous as vol
import logging
from homeassistant.components.sensor import (
PLATFORM_SCHEMA,
SensorDeviceClass,
SensorEntity,
SensorStateClass,
from homeassistant.const import CONF_ID, CONF_NAME
from homeassistant.core import HomeAssistant
from homeassistant.helpers.entity_platform import AddEntitiesCallback
from homeassistant.helpers.typing import ConfigType, DiscoveryInfoType
import homeassistant.helpers.config_validation as cv
from .const import (
DOMAIN, # noqa
SCAN_INTERVAL, # noqa
CONF_GLOBALID,
# integration imports start
# removed
# integration imports end
DEFAULT_NAME = "S-Bahn"
_LOGGER = logging.getLogger(__name__)
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend(
vol.Required(CONF_GLOBALID): cv.string,
vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
async def async_setup_platform(
hass: HomeAssistant,
config: ConfigType,
add_entities: AddEntitiesCallback,
discovery_info: DiscoveryInfoType | None = None,
) -> None:
"""Set up the sensor platform."""
name = config[CONF_NAME]
globalid = config[CONF_GLOBALID]
add_entities([ConnectionInfo(hass, globalid, name)], True)
class ConnectionInfo(SensorEntity):
def __init__(self, hass, globalid, name) -> None:
self._globalid = globalid
self._name = name
self._attr_name = name
self._hass = hass
self._hass.custom_attributes = {}
@property
def name(self) -> str:
"""Return the name."""
return self._name
@property
def device_state_attributes(self):
"""Return the state attributes of the sensor."""
return self._hass.custom_attributes
@property
def unique_id(self) -> str:
"""Return a unique, Home Assistant friendly identifier for this entity."""
return self._globalid.replace(":", "")
# removed
def update(self) -> None:
"""Fetch new state data for the sensor."""
_LOGGER.error("UPDATE - Test, if integration is running")
self._attr_native_value = "" + self.abfahrt()
attributes = {}
attributes['delay'] = '1'
attributes['linie'] = 'S3'
attributes['destination'] = 'Far Far Away'
self._hass.custom_attributes = attributes
This value is available in HA
at the moment I have everything in 1 line, means the next departures in 1 line without formating
This is not available in HA
attributes = {}
Any idea why ?
