On my 8Gb 120Gb SSD NUC with Homeassistant OS a snapshot takes 2-3 hours to finish.The snapshot size is about 4-5 Gb. My InfluxDB is probably the largest part. Is this normal?
On my test system (same specs, same config, smaller InfluxDB) a snapshot is done in minutes.
started a backup at 12:00, now its 13:36 and according to Supervisor Logs its still doing a backup of influxdb…
It would be great to have some sort of progres-bar or percentage sensor how far the backup is, or at least a binary sensor that the backup is (still) in progres…
I start the backup with a service call so I do not see when it finishes, I need to either check the supervisor logs or to look into the backups section if the new backup was created…
HW: Rpi4 4GB with an external 1TB USB-HDD connected with 3.0, backup size 2,9 GB, HASS-DB Size 1,59 GB.
