Create status rest_command.ducobox_mode_man1
Hi!
I would like to create statuses for three actions. These statuses are not found in “statuses” at the moment. Is there a way to do this? the statuses should be on/off
This are the used codes now:
show_icon: true
type: custom:mushroom-template-card
primary: Laag
secondary: null
layout: vertical
tap_action:
  action: perform-action
  perform_action: rest_command.ducobox_mode_man1
  target: {}
entity: input_select.ducobox_mode
hold_action:
  action: none
icon: mdi:fan-speed-1
icon_color: blue
And i would like to create somthing like this:
            primary: Deur dakterras
            secondary: '{{states(''sensor.alarmsysteem_temperature_01'')}} graden'
            icon: |2-
               {% set dooropen = states('sensor.alarmsysteem_magnet_01') %}{% if dooropen == 'on'
                        %}mdi:door-closed{% else %}mdi:door-open{% endif %}
            entity: sensor.alarmsysteem_magnet_01
            icon_color: |2-
                        %}green{% else %}red{% endif %}
            layout: vertical
            multiline_secondary: true
            fill_container: false
            picture: ''
            tap_action:
              action: none
            hold_action:
              action: none
            double_tap_action:
              action: none
Thank you!
