Create Templates for states in hierarchy
So this is probable quite straight forward, but havent found any info on this
How can I return the state values from the “Forecast”?
Thanks,
this will give you the complete forecast info:
{{ state_attr('weather.ug', 'forecast') }}
then you can select sub info like this:
{{ state_attr('weather.ug', 'forecast')[0].temperature }}
which will give you the temperature from the first section of the forecast.
Perfect, just what I needed. Thx a lot!
