Create Thermostat
This is the log events while we operate the temperature from the wall, but we need to operate the same with the Apple Home App.
Please advise us.
297948
Oct 4, 2024, 3:59:20 PM GMT+2
DEBUG
knxgw
KNX Gateway (name:gw-0) server routine received event: Write 1.2.19->7/0/1 [000064]
297949
DEBUG
mdm
Received message: event/knx-interactor/1/0xFC0E/0xF001 [KNXInteractorCluster_GroupAddressValueEvent, value={0 7/0/1 Sollwertverschiebung [0 0 100] [0 0 50] true 1.2.19 0 2} (knx.KNXInteractorCluster_GroupAddressValueEventData)]
[TraceID: 80b1b612-54a3-4e1a-9bdd-f8deb2d24f45]
297950
DEBUG
mdm
Sending message to callback ‘matter-bridge-event’ (id: 4) with message event/knx-interactor/1/0xFC0E/0xF001 [KNXInteractorCluster_GroupAddressValueEvent, value={0 7/0/1 Sollwertverschiebung [0 0 100] [0 0 50] true 1.2.19 0 2} (knx.KNXInteractorCluster_GroupAddressValueEventData)] using mask message-mask/event/
297951
TRACE
apps/mbridge
Skipping sending event - bridgeToMatter disabled, message=knx-interactor/1/0xFC0E/0xF001 [KNXInteractorCluster_GroupAddressValueEvent, value={0 7/0/1 Sollwertverschiebung [0 0 100] [0 0 50] true 1.2.19 0 2} (knx.KNXInteractorCluster_GroupAddressValueEventData)]
297952
Oct 4, 2024, 3:59:21 PM GMT+2
DEBUG
knxgw
KNX Gateway (name:gw-0) server routine received event: Write 1.2.4->7/0/2 [000c4c]
297953
DEBUG
mdm
Received message: event/knx-interactor/1/0xFC0E/0xF001 [KNXInteractorCluster_GroupAddressValueEvent, value={0 7/0/2 aktueller Sollwert [0 12 76] [0 13 20] true 1.2.4 0 2} (knx.KNXInteractorCluster_GroupAddressValueEventData)]
297954
DEBUG
mdm
Sending message to callback ‘matter-bridge-event’ (id: 4) with message event/knx-interactor/1/0xFC0E/0xF001 [KNXInteractorCluster_GroupAddressValueEvent, value={0 7/0/2 aktueller Sollwert [0 12 76] [0 13 20] true 1.2.4 0 2} (knx.KNXInteractorCluster_GroupAddressValueEventData)] using mask message-mask/event/
297955
TRACE
apps/mbridge
Skipping sending event - bridgeToMatter disabled, message=knx-interactor/1/0xFC0E/0xF001 [KNXInteractorCluster_GroupAddressValueEvent, value={0 7/0/2 aktueller Sollwert [0 12 76] [0 13 20] true 1.2.4 0 2} (knx.KNXInteractorCluster_GroupAddressValueEventData)]
[image]
Following log events are when I operate form the Apple Home App
326746
Oct 4, 2024, 4:19:42 PM GMT+2
DEBUG
knxgw
KNX Gateway sending GroupEvent Write 0.0.0->7/0/2 [0086a2]
326754
DEBUG
mdm
Received message: event/knx-interactor/1/0xFC0E/0xF001 [KNXInteractorCluster_GroupAddressValueEvent, value={0 7/0/2 aktueller Sollwert [0 134 162] [0 7 108] true 0.0.0 0 2} (knx.KNXInteractorCluster_GroupAddressValueEventData)]
326755
DEBUG
mdm
Sending message to callback ‘matter-bridge-event’ (id: 4) with message event/knx-interactor/1/0xFC0E/0xF001 [KNXInteractorCluster_GroupAddressValueEvent, value={0 7/0/2 aktueller Sollwert [0 134 162] [0 7 108] true 0.0.0 0 2} (knx.KNXInteractorCluster_GroupAddressValueEventData)] using mask message-mask/event/
326757
TRACE
apps/mbridge
Skipping sending event - bridgeToMatter disabled, message=knx-interactor/1/0xFC0E/0xF001 [KNXInteractorCluster_GroupAddressValueEvent, value={0 7/0/2 aktueller Sollwert [0 134 162] [0 7 108] true 0.0.0 0 2} (knx.KNXInteractorCluster_GroupAddressValueEventData)]
326919
Oct 4, 2024, 4:20:12 PM GMT+2
DEBUG
knxgw
KNX Gateway sending GroupEvent Write 0.0.0->7/0/2 [000c4c]
326927
DEBUG
mdm
Received message: event/knx-interactor/1/0xFC0E/0xF001 [KNXInteractorCluster_GroupAddressValueEvent, value={0 7/0/2 aktueller Sollwert [0 12 76] [0 134 162] true 0.0.0 0 2} (knx.KNXInteractorCluster_GroupAddressValueEventData)]
326928
DEBUG
mdm
Sending message to callback ‘matter-bridge-event’ (id: 4) with message event/knx-interactor/1/0xFC0E/0xF001 [KNXInteractorCluster_GroupAddressValueEvent, value={0 7/0/2 aktueller Sollwert [0 12 76] [0 134 162] true 0.0.0 0 2} (knx.KNXInteractorCluster_GroupAddressValueEventData)] using mask message-mask/event/
326930
TRACE
apps/mbridge
Skipping sending event - bridgeToMatter disabled, message=knx-interactor/1/0xFC0E/0xF001 [KNXInteractorCluster_GroupAddressValueEvent, value={0 7/0/2 aktueller Sollwert [0 12 76] [0 134 162] true 0.0.0 0 2} (knx.KNXInteractorCluster_GroupAddressValueEventData)]
326974
Oct 4, 2024, 4:20:13 PM GMT+2
DEBUG
knxgw
KNX Gateway (name:gw-0) server routine received event: Write 1.2.4->7/0/4 [00]
326975
DEBUG
mdm
Received message: event/knx-interactor/1/0xFC0E/0xF001 [KNXInteractorCluster_GroupAddressValueEvent, value={0 7/0/4 Stellwert schaltend [0] [0] true 1.2.4 0 2} (knx.KNXInteractorCluster_GroupAddressValueEventData)]
326976
DEBUG
mdm
Sending message to callback ‘matter-bridge-event’ (id: 4) with message event/knx-interactor/1/0xFC0E/0xF001 [KNXInteractorCluster_GroupAddressValueEvent, value={0 7/0/4 Stellwert schaltend [0] [0] true 1.2.4 0 2} (knx.KNXInteractorCluster_GroupAddressValueEventData)] using mask message-mask/event/
326977
TRACE
apps/mbridge
Skipping sending event - bridgeToMatter disabled, message=knx-interactor/1/0xFC0E/0xF001 [KNXInteractorCluster_GroupAddressValueEvent, value={0 7/0/4 Stellwert schaltend [0] [0] true 1.2.4 0 2} (knx.KNXInteractorCluster_GroupAddressValueEventData)]
This is a forum for the Home Assistant software.
It is not a general software for home automation systems.
There might be some users here that can help with the Apple Home app, but if you are here, then it is generally because you have decided that Apple Home was not good enough.
