Hi!
Is there a possibility to create a virtual shutter device that acts like a normal shutter device, to add new properties and functions to the virtual shutter device.
For example, the virtual shutter device inherits all functions from the normal shutter device, but it adds the property ‘locked’. So is the command open or close is send to the virtual shutter device, it looks, if ‘locked’ is true. If not, it calls the corresponding function of the real device (for example shelly shutter). If ‘locked’ is true, it does nothing.
Yes, you are right, I could use automations and binary helpers, but if I could create a virtual shutter device, I could use the normal logic and functions of home assistant, for example shutter groups.
So you have an idea about that?
Thanks!
