Created a blueprint for linking On/Off/Brightness for smart switch and shelly dimmers
Hi Guys
I created a new blueprint for linking my smart switches as well as shelly dimmer together.
So far I am very happy with it, seems to do its job.
Please feel free to comment on it, if you think there are things missing, or whatever.
Description below
Synchronize Entities for On, Off, and Brightness Control
This blueprint allows you to synchronize multiple entities for controlling their on/off state and brightness level. It simplifies the experience of managing devices by ensuring they respond consistently, regardless of which entity you use.
Overview
Imagine you have two wall switches in your corridor. Turning on the first one will also indicate the light's status on the second switch. You can adjust brightness from any device, whether it's a mobile app or a physical switch.
Key Features
 - When one entity is turned on or off, the others will follow suit.
 - Changing brightness on one entity will update the brightness for all linked entities.
Requirements
 - Brightness attribute must be a numeric brightness value, not a step up/down indicator.
 - All selected entities MUST support `homeassistant.turn_on` and `homeassistant.turn_off`.
 - Tested on Home Assistant version 2023.09.
Tested Devices
 - Moes wall smart switch (non-dimmer)
 - Moes wall smart switch with dimmer functionality
 - Shelly Dimmer 2
Credits
- Inspiration and starting point from @aderusha's [Link On/Off State of Multiple Devices](https://gist.github.com/aderusha/4d2c8600a2e4771b91b8efc555946413)
Thank you for the amazing contribution @bthuree.
I have tested this using a couple of Shelly Dimmer2 devices. Only one of these devices is connected to physical switches.
When turning the devices on or off, or changing brightness levels, in the Shelly App, using HA or directly on the Shelly devices’ web page, it all works perfectly.
When using the physical buttons, there is an odd rebound effect. For example, when you use the physical button to turn the attached lamps on, it does this for a very short duration, then the second device turns on, then first device turns off, followed by the second device. It is the same effect when changing brightness or turning off using the physical buttons.
Would it be possible to modify the code to have a master/ slave relationship rather than them both synced together?
@bthuree would you be able to extend this Blueprint to work with Entity Groups?
Essentially allowing us to simply put in a Group or set of Groups, not individual entities?
The value would be that we could create Groups for any set of dimmers or switches. These groups can change over time, and be leveraged by many many things in HA.
Using groups help greatly reduce re-work for building/updating Automations.
thx!
Hello bthuree,
Thanks for contributing to the community with a Blueprint.
I have a suggestion for you. Many people who are not familiar with directory structures will have problems installing this without the Home Assistant MY tools.
Adding a MY link for this Blueprint to your top post would help them a lot.
Here is the link to make that.
Create a link – My Home Assistant
Thank you @bthuree, this is exactly what I’m looking for!
However, when using them with Simon switches, I face similar issues to @KB84. I see that you have a initiating_automation_id variable that is unused. I’m unsure if that can be used to kill the feedback/rebound loop.
Just tried it with some Tuya wifi smart dimmer switch and a set of Tuya wifi smart bulbs....all running under Tuya Local. Works perfectly and exactly what I needed.
