Creating a alarm clock
I didn’t find a component to create an alarm clock for my difficult morning, so i implement that.
It’s composed with simple modules :blush:
input_boolean :
  reveil:
    name: Reveil positionné
    initial: off
    icon: mdi:alarm
  lightreveil:
    initial: off
    icon: mdi:theme-light-dark
We declare 2 input_boolean to turn on the TV and to turn on bedroom’s light
input_select:
  choixreveil:
    icon: mdi:alarm
    initial: "06:35"
    options:
      - "06:00"
      - "06:05"
      - "06:10"
      - "06:15"
      - "06:20"
      - "06:25"
      - "06:30"
      - "06:35"
      - "06:40"
      - "06:45"
      - "06:50"
      - "06:55"
      - "07:00"
      - "07:05"
      - "07:10"
      - "07:15"
      - "07:20"
      - "07:25"
      - "07:30"
      - "07:35"
      - "07:40"
      - "07:45"
      - "07:50"
      - "07:55"
Automation to turn on TV
  - alias: "reveil matin 06h20"
      - platform: time
        after: "06:20:00"
    condition:
      - platform: state
        entity_id: input_boolean.reveil
        state: 'on'
      - platform: state
        entity_id: input_select.choixreveil
        state: "06:20"
      service: shell_command.allumefreebox
Automation to turn on bedroom’s light (with transistion).
  - alias: "aurora 06h10"
      - platform: time
        after: "06:08:00"
    condition:
      - platform: state
        state: 'on'
      - platform: state
        entity_id: input_boolean.lightreveil
        state: "on"
      - platform: state
        state: "06:10"
      service: light.turn_on
      entity_id: light.chambre
       transition: 120
It looks great, what does it mean in English?
Reveil matin (“Alarm clock”)
reveil positionné (a boolean to turn on TV the morning) in english “alarm clock is on”
reveil naturel (a boolean to turn on the light the morning) in english “natural wakeup”
To turn on TV a shell command is called. This shell command runs http request to internet box to control it.
This is pretty cool! Any ideas why when I copy this section into my config:
input_boolean :
  reveil:
    initial: off
    icon: mdi:alarm
  lightreveil:
    initial: off
I get a box with the name “Input Boolean” like this:
How did you get the outer box with the name “Reveil Martin”?
Thanks!
You have to ‘customize’ your items.
thanks for sharing this. but i cannot understand the automation.
The time is suppose to be dynamic, right? Shouldn’t it follows the time I select in the input_select dropdown? The automation seems to work only on 6.20.
Please correct me if I am wrong.
@masterkenobi You’ll have to write an “automation rule” for every item on the input_select option.
ah… that’s what I am afraid of. it seems impractical to repeat the block of codes for every input_select options. Imagine, if I have 50 options, I have to repeat the same automation rule (with changes to the time) for 50 times! The most practical way to approach this is via loop but I can’t figure out how to do so in HASS.
Do you have any idea?
Not a perfect way but… triggering an automation every…5 min. and having a condition comparing actual time with input_select state:
automation:
  - alias: "Alarm clock"
      platform: time
      minutes: '/5'
    condition:
      platform: template
      # this will report true if time in input_select (in format HH:MM ) is equal to actual time
      value_template: '{{ now.time().strftime("%H:%M") == states.input_select.alarm_clock.state }}'
#your action here
If you wanna try, report if it works.
thanks a lot. i have tried it. for action, i just made it to send notification via pushbullets. when the alarm is triggered, I received countless notifications non-stop. any idea what went wrong?
Can you post some logs from alarm triggering? I haven’t tested the code on my config, as I have only 3 options in my input_select, but tested the condition on template editor from hass page and it return False almost all the time, so in theory shouldn’t trigger so often.
somehow i manage to fix it by adding seconds: 0 under the trigger.
By the way, in my input_select, the time option is using 15 minutes steps. For example…
alarmclock:
  icon: mdi:alarm
  initial: "09:00"
  options:
    - "05:00"
    - "05:15"
    - "05:30"
    - "05:45"
    - "06:00"
    - "06:15"
    - "06:30"
    - "06:45"
    - "07:00"
    - "07:15"
    - "07:30"
    - "07:45"
    - "08:00"
    - "08:15"
    - "08:30"
    - "08:45"
    - "09:00"
    - "09:15"
    - "09:30"
    - "09:45"
    - "10:00"
    - "23:15"
    - "23:30"
    - "23:45"
    - "00:00"
Is it correct if I change the automation trigger to minutes: '/15' ?
Sure! As you have mostly 15 minutes intervals, /15 should be ok.
it works like a charm this morning. I have modified the script to add another input_boolean of “Weekdays Only” so that the alarm only runs on weekdays if it is ‘On’. Here is what i did…
input_boolean:
  alarmweekday:
    initial: off
    icon: mdi:alarm
automation:
  - alias: 'Alarm Clock'
      platform: time
      minutes: '/15'
      seconds: 0
    condition:
      - platform: state
        entity_id: input_boolean.alarmstatus
        state: 'on'
        value_template: '{% if is_state("input_boolean.alarmweekday", "on") %}{{ now.time().strftime("%H:%M") == states.input_select.alarmclock.state and (now.time().strftime("%a") == "Mon" or now.time().strftime("%a") == "Tue" or now.time().strftime("%a") == "Wed" or now.time().strftime("%a") == "Thu" or now.time().strftime("%a") == "Fri") }}{% else %}{{ now.time().strftime("%H:%M") == states.input_select.alarmclock.state }}{% endif %}'
      service: notify.notify
        message: 'Time to Wake Up'
        title: ""
Yeah ! thanks to you two for that i experiment that tomorrow.
any idea for that
  - alias: "aurora 06h00"
      - platform: time
        after: "05:50:00"
    condition:
      - platform: state
        state: 'on'
      - platform: state
        state: "on"
      - platform: state
        state: "06:00"
       transition: 600
  - alias: "aurora 06h05"
      - platform: time
        after: "05:55:00"
    condition:
      - platform: state
        state: 'on'
      - platform: state
        state: "on"
      - platform: state
        state: "06:05"
       transition: 600
I think thatr is impossible to substract minutes to time in a value_template …
How do you like this version
input_slider:
  slider_houres:
    initial: 6
    min: 0
    max: 23
    step: 1
  slider_minutes:
initial: 0
min: 0
max: 55
step: 5
Automation:
- alias: Alarm Clock Slider
      platform: time
      minutes: '/5'
      seconds: 0
   condition:
    - platform: state
      state: 'on'
      value_template: '{{ now.time().strftime("%H") == states.input_slider.slider_houres.state and now.time().strftime("%M") == states.input_slider.slider_minutes.state }}'
      entity_id: light.ground_light
Slider seems neater way to do it. Thanks. Will try it out.
It seems there is a problem with the code. The slider value for below 10 is only one digit, whereas the below 10 value for now.time().strftime("%H") or now.time().strftime("%M") are zero-padded. So, the above conditional statement for hour or minute below 10 will always return false.
To rectify this, just change to this…
now.time().strftime("%-H")
or
now.time().strftime("%-M")
Refering to http://strftime.org/
Yes. morning noticed that too . In the evening, everything worked perfectly :slight_smile:
I believe you could just move the value template line into the trigger section. That way you don’t need the part that checks the time every 15 minutes. so far it works for me.
  platform: template
  value_template: '{{ now.time().strftime("%-H") == states.input_slider.slider_houres.state and now.time().strftime("%-M") == states.input_slider.slider_minutes.state }}'
