What’s the point of setting the finish time? Do you have any events triggered on that value?
it’s in appdaemon so it’s all python code. But I will post it in a while, still have a couple of changes and some personal information to move elsewhere.
please share your code
will do once it’s documented and cleaned up.
Only to turn off the lights and radio in the bedroom, I just find it easy to use the sliders to set the off time, I suppose you could use a delay and templates to do the same thing. Next on the list is a snooze button
That’s what I use
OK, here it is…
In Configuration.yaml
input_slider:
alarmhour:
icon: mdi:timer
initial: 06
min: 0
max: 23
step: 1
alarmmins:
icon: mdi:timer
initial: 10
min: 0
max: 59
step: 1
alarmfinishhr:
icon: mdi:watch-export
initial: 06
min: 0
max: 23
step: 1
alarmfinishmins:
initial: 30
min: 0
max: 55
step: 5
In input_boolean.yaml
alarmstatus:
name: Wake Me Up
initial: on
icon: mdi:alarm-check
alarmweekday:
initial: on
icon: mdi:calendar
In groups.yaml
alarmclock:
name: Wake Me Up
#view: yes
entities:
- sensor.alarm_time
- input_slider.alarmhour
- input_slider.alarmmins
- input_boolean.alarmstatus
- input_boolean.alarmweekday
- sensor.alarm_time_fin
- input_slider.alarmfinishhr
- input_slider.alarmfinishmins
alrmclock:
name: Wake Me Up!
view: yes
entities:
- group.alarmclock
In automation.yaml
- alias: 'Wake Me Up'
- platform: time
minutes: '/1'
seconds: 0
condition:
condition: or
conditions:
- condition: and
conditions:
- condition: state
entity_id: input_boolean.alarmstatus
state: 'on'
- condition: state
entity_id: input_boolean.alarmweekday
state: 'on'
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- sat
- condition: template
value_template: '{{ now().time().strftime("%R") == states.sensor.alarm_time.state }}'
- condition: and
conditions:
- condition: state
state: 'on'
- condition: state
state: 'off'
- service: notify.mypushbullet
title: "Alarm"
message: "Good morning Sir. Time to Wake Up!"
- service: switch.turn_on
entity_id:
- switch.bedroom_pc_lamp
- switch.bedroom_red_bottom_lamp
- switch.bedroom_uplight_bluebottom
- light.bedroom_ceiling_light
- switch.bedroom_pc__sound
entity_id:
- switch.foobaralarm
- alias: Turn off Alarm
- platform: time
minutes: '/1'
seconds: 0
condition:
value_template: '{{ now().time().strftime("%R") == states.sensor.alarm_time_fin.state }}'
- service: switch.turn_off
entity_id:
title: "Alarm Finished"
message: "You should be Up by Now!"
entity_id:
Enjoy
thanks you
I think you forgot your sensors (alarm_time and alarm_time_fin), unless they were mentioned earlier already of course. Didn’t read the whole threat. But cool work!
yep
sensors:
alarm_hour:
# friendly_name: 'Hour'
value_template: '{{ states("input_slider.alarmhour") | round(0) }}'
alarm_minutes:
# friendly_name: 'Minutes'
value_template: '{{ states("input_slider.alarmmins") | round(0) }}'
alarm_time:
friendly_name: 'Time'
value_template: '{% if states("sensor.alarm_hour")|length == 1 %}0{% endif %}{{ states("sensor.alarm_hour") }}:{% if states("sensor.alarm_minutes")|length == 1 %}0{% endif %}{{ states("sensor.alarm_minutes") }}'
alarm_hour_fin:
# friendly_name: 'FinHour'
value_template: '{{ states("input_slider.alarmfinishhr") | round(0) }}'
alarm_minutes_fin:
# friendly_name: 'FinMinutes'
value_template: '{{ states("input_slider.alarmfinishmins") | round(0) }}'
alarm_time_fin:
friendly_name: 'FinTime'
value_template: '{% if states("sensor.alarm_hour_fin")|length == 1 %}0{% endif %}{{ states("sensor.alarm_hour_fin") }}:{% if states("sensor.alarm_minutes_fin")|length == 1 %}0{% endif %}{{ states("sensor.alarm_minutes_fin") }}'
Consider this. To be fair, I copy/pasted & adapted it from an earlier entry in this topic
alarm_time:
friendly_name: "Alarm start time"
value_template: '{{ "%0.02d:%0.02d" | format(states("input_slider.alarmhour") | int, states("input_slider.alarmmins") | int) }}'
alarm_time_fin:
friendly_name: "Alarm end time"
value_template: '{{ "%0.02d:%0.02d" | format(states("input_slider.alarmfinishhr") | int, states("input_slider.alarmfinishmins") | int) }}'
Look good and is certainly more compact
does it work so that you get a leading zero?
I extended my alarm clock with a Lullaby option
Lullaby initiates with a HTTP Post command which is send from Tasker when I lay my phone on the wireless charger next to my bed. It first changes the sliders (via MQTT) to a different value and then to the value of which my alarmtime is set (readout with AutoAlarm). Then it recalculates the time left untill my next alarm, sends this as TTS to my bedroom speaker and finally fires the Lullaby trigger (if it’s set to “On” of course).
If anyone is intrerested in the configurations, let me know.
I have interest.share with us please.
Ok here we go. Perhaps it has gotten way to complicated but this is my result after HOURS and HOURS of trial and error ( with a lot of help from the experts on this forum) and it seems to do the job pretty well
Sensors:
sensors:
alarmtime:
friendly_name: Wakeup Time
entity_id:
- input_slider.alarm_hour
- input_slider.alarm_minutes
value_template: '{{ "%0.02d:%0.02d" | format(states("input_slider.alarm_hour") | int, states("input_slider.alarm_minutes") | int) }}'
nextalarm:
friendly_name: Seconds untill next alarm
entity_id:
value_template: >
{% set relative_time = (states.input_slider.alarm_hour.state|float|multiply(60) + states.input_slider.alarm_minutes.state|float) - (now().hour|float|multiply(60) + now().minute) %}
{%- if relative_time < 0 -%}
{{23*60+relative_time}}
{%- else -%}
{{ relative_time-60}}
{%- endif %}
time_until_alarm:
friendly_name: Time untill next alarm
entity_id:
- sensor.nextalarm
value_template: '{{ (states.sensor.nextalarm.state.split(" ")[0] | int *60 ) | timestamp_custom("%H:%M") }}'
Automation for wakeup light with radio:
- alias: 'Wakeup Light with Radio'
platform: time
minutes: '/5'
seconds: '0'
condition:
condition: and
conditions:
value_template: '{{ ((now().strftime("%s") | int + 1200) | timestamp_custom("%H:%M")) == states.sensor.alarmtime.state }}'
- condition: state
entity_id: input_boolean.alarm_clock
state: 'on'
- service: light.turn_on
entity_id: light.bed_room
brightness: 255
rgb_color: [255,255,255]
transition: 1200
- service: media_player.play_media
data_template:
entity_id: media_player.bed_room
media_content_id: >
{% if is_state("input_select.radio_wakeup", "Radio 538") %} http://vip-icecast.538.lw.triple-it.nl:80/RADIO538_MP3
{% elif is_state("input_select.radio_wakeup", "Q-Music") %} http://icecast-qmusic.cdp.triple-it.nl/Qmusic_nl_live_96.mp3
{% elif is_state("input_select.radio_wakeup", "3FM") %} http://icecast.omroep.nl/3fm-bb-mp3
{% elif is_state("input_select.radio_wakeup", "100% NL") %} http://stream.100p.nl/100pctnl.mp3
{% elif is_state("input_select.radio_wakeup", "Veronica") %} http://8543.live.streamtheworld.com/VERONICACMP3
{% elif is_state("input_select.radio_wakeup", "Sky Radio") %} http://8623.live.streamtheworld.com:80/SKYRADIOAAC_SC
{% elif is_state("input_select.radio_wakeup", "Arrow Classic Rock") %} http://91.221.151.155/listen.mp3
{% elif is_state("input_select.radio_wakeup", "Classic FM") %} http://19143.live.streamtheworld.com/CLASSICFM_SC
{% elif is_state("input_select.radio_wakeup", "BNR Nieuwsradio") %} http://icecast-bnr.cdp.triple-it.nl/bnr_mp3_96_03
{% endif %}
media_content_type: 'audio/mp4'
- service: media_player.volume_set
volume_level: '0.01'
- delay: '00:02:00'
volume_level: '0.05'
- delay: '00:02:00'
volume_level: '0.10'
- delay: '00:01:30'
volume_level: '0.15'
- delay: '00:01:30'
volume_level: '0.20'
- delay: '00:01:30'
volume_level: '0.25'
- delay: '00:01:00'
volume_level: '0.30'
- delay: '00:01:00'
volume_level: '0.35'
- delay: '00:01:00'
volume_level: '0.40'
- delay: '00:01:00'
volume_level: '0.45'
- delay: '00:01:00'
volume_level: '0.50'
- delay: '00:01:00'
volume_level: '0.55'
- delay: '00:00:45'
volume_level: '0.60'
- delay: '00:00:45'
volume_level: '0.65'
- delay: '00:00:45'
volume_level: '0.70'
- delay: '00:02:00'
entity_id: light.hall_way
brightness: 125
entity_id: light.diner_table
brightness: 125
entity_id: light.living_room
brightness: 140
entity_id: media_player.ca_bathroom
- delay: '00:00:10'
data_template:
media_content_id: >
{% endif %}
- service: homeassistant.turn_off
Automations for changing alarm time triggered through MQTT, sent through Tasker:
- alias: Set alarmtime_hour
platform: mqtt
topic: "setHour"
service: input_slider.select_value
data_template:
entity_id: input_slider.alarm_hour
value: '{{ trigger.payload}}'
- alias: Set alarmtime_minutes
platform: mqtt
topic: "setMinutes"
data_template:
entity_id: input_slider.alarm_minutes
Script for executing lullaby and gently decreasing volume over 30 mins:
sleep:
alias: Good Night
sequence:
- alias: Set Volume
volume_level: '1.0'
- alias: Say Sleep Left
service: tts.google_say
data_template:
message: 'Next alarm in {{ (states.sensor.nextalarm.state.split(" ")[0] | int *60 ) | timestamp_custom("%H") | int }} hours and {{ (states.sensor.nextalarm.state.split(" ")[0] | int *60 ) | timestamp_custom("%M") }} minutes . Good night.'
cache: false
- delay: '00:00:15'
- alias: Set Volume2
volume_level: '0.75'
- condition: state
entity_id: input_boolean.lullaby
state: 'on'
data_template:
media_content_id: >
{% if is_state("input_select.lullaby", "Sleep Radio") %} http://37.59.28.208:8722/stream
{% elif is_state("input_select.lullaby", "Ambient Sleeping Pill") %} http://perseus.shoutca.st:8447/h
{% elif is_state("input_select.lullaby", "Radio Art - Sleep") %} http://live.radioart.com/fSleep.mp3
{% elif is_state("input_select.lullaby", "Ambi Nature Radio") %} http://94.23.252.14:8067/stream
{% elif is_state("input_select.lullaby", "Calm Radio - Sleep") %} http://streams.calmradio.com/api/39/128/stream
{% endif %}
- delay: '00:05:00'
- delay: '00:02:30'
- delay: '00:02:30'
- delay: '00:05:00'
- delay: '00:02:30'
- delay: '00:02:30'
- delay: '00:05:00'
- delay: '00:02:30'
- delay: '00:02:30'
- delay: '00:05:00'
Input sliders, selectors and booleans:
input_boolean:
alarm_clock:
initial: off
icon: mdi:alarm
lullaby:
initial: On
icon: mdi:sleep
input_slider:
alarm_hour:
icon: mdi:timer
initial: 6
min: 0
max: 23
step: 1
alarm_minutes:
icon: mdi:timer
initial: 35
min: 0
max: 55
step: 5
input_select:
radio_wakeup:
name: Wakeup Radio Station
options:
- Radio 538
- Q-Music
- 3FM
- 100% NL
- Veronica
- Sky Radio
- Arrow Classic Rock
- Classic FM
- BNR Nieuwsradio
initial: Radio 538
icon: mdi:radio
lullaby:
name: Lullaby Radio Station
options:
- Sleep Radio
- Ambient Sleeping Pill
- Radio Art - Sleep
- Ambi Nature Radio
- Calm Radio - Sleep
initial: Ambient Sleeping Pill
icon: mdi:music-circle
Frontend view:
group:
Wake-up Alarm:
name: Wakeup Light with Radio
entities:
- input_boolean.alarm_clock
- sensor.alarmtime
- sensor.time_until_alarm
- input_boolean.lullaby
- input_select.lullaby
- input_select.radio_wakeup
I made a video guide for how to make an alarm clock from start to finish. It might be useful if you’re stuck.
Similarly to you Bob_NL, I’ve used the following succesfully:
'{{ (now().strftime("%s") | int | timestamp_custom("%H:%M")) == states.input_select.alarmtime.state }}
However, unlike you, the following does not work for me:
'{{ ((now().strftime("%s") | int + 1200) | timestamp_custom("%H:%M")) }} == {{ states.input_select.alarmtime.state }}'
I’ve spent hours tweaking with no success. I’d ideally like the automation to run x amount of time before the alarm time. Anybody any ideas?
Hey @davemccrea ! So if I understand you correct I should be doing precicely that with my alarm clock on hass. What I wanted to do was trigger my automation 5 minutes EARLIER than the alarm time you choose.
All I did was a have a second template sensor for the time like so:
alarm_time:
friendly_name: ‘Time with offset’
value_template: ‘{{ “%0.02d:%0.02d” | format(states(“input_slider.alarmhour”) | int, states(“input_slider.alarmminutes”) | int - 5) }}’
So my trigger uses the above like so:
platform: template
value_template: ‘{{ states.sensor.time.state == states.sensor.alarm_time.state }}’
As for the hass front end/ui “time” I basscially have another time sensor display the correct time when you choose with the sliders, and viola, it works for me
EDIT: ugh the code formating on the forum is not workingproperly for me
Thanks for the code @lv-88! Could do the trick …
What happens, as an example, if you set your alarm for 0703? Am I right in saying that the automation would begin at 0700 rather than 0658?
Well that won’t happen in my case since I have incremental steps of 5 for the minute slider, but if it didn’t have it I guess you are correct
