Creating a customized switch
i want to have a switch which when switched on (from the lovelace UI) will set a boolean to true and run a script, and when switched off - to set the boolean to false. i tried to create the following - i’m not sure if that’s the right way to achieve this:
  switch:
      switches:
        ac1_auto_mode:
          friendly_name: 'AC1 Auto Mode Set'
          value_template: "{{ is_state('switch.source', 'on') }}"
          turn_on:
              entity_id: input_boolean.ac1_auto_mode
          - service: script.auto_ac1_init
              ac: 1
              init: 1
          turn_off:
          - service: input_boolean.turn_off
i’m not sure how to set the “value_template” here. currently - when the switch is switched on, it returns to be off after a second.
Input booleans look like switches in the front end. Why are duplicating it with a switch?
Create your input boolean.
Trigger automations on change the state of the input boolean to do your actions.
great idea - changing - thx
