I have two sensors; one in my pool and one in my solar panel. The solar panel has a small pump that is soon to be upgraded.
I currently have an automation based on this sensor that turns on the solar pump when the solar panel is 1°C warmer than the pool and off otherwise.
sensors:
temp_diff:
friendly_name: Temperature Difference
value_template: "{{((states.sensor.solar_temperature.state | float ) - (states.sensor.pool_temperature.state | float)) > 1}}`
- id: ID12
alias: 'Pump hot water if hotter than pool'
initial_state: 'on'
- platform: state
entity_id: binary_sensor.temp_diff
to: 'on'
- service: switch.turn_on
entity_id: switch.solar_pump
- id: ID13
alias: 'Stop solar pump if colder than pool'
initial_state: 'on'
- platform: state
to: 'off'
- service: switch.turn_off
As I’m going to increase the flow rate from 360l/hr to 5200l/hr, I need to allow a short time (unknown) for the water to heat inside the solar panel so I want the pump to start when the solar panel is say 4 °C above the pool temp (possibly using an input_number slider), then off when the difference drops to say 0.5°C
Anyone know the best way to create that automation?
PS - the forum says I’ve edited that once, but it was actually about 6 times to get the formatting right (and it still might not be!!) so don’t copy it from the email you got!
@anon43302295 Wow, that was fast and awesome. I’m always in awe of you coding guys that can bang out stuff like that effortlessly. Wish I could do that.
0124 in the morning here in NZ so I’ll give that a try when the sun comes up! Thank you.
Just beware that it might need a bit of tweaking to make sure that the pump doesn’t end up on when you don’t want it to be, it’s hard to run through the permutations when you’re not looking at the system and imagining it running.
Also, as it is there, you could potentially set the OFF offset higher than the ON offset and so on, which could lead to it never coming on, or getting stuck on or whatever. So once you’ve got it working the code might need refining slightly to prevent errrors creeping in.
Got this working tonight and seems to be behaving exactly as I wanted so thank you. Not withstanding that the cooked pump I had took out my PWM controlled MOSFET so had to rip out my solar controller and replace that too!
Seems something is not quite right. With the solar pump off and the on_offset set to 2 and the off_offset set to 0.5, the pump starts when the 2 degrees differential hits and then turns off when it get to just below 0.5 degrees which is great. However, it seems to turn back on when the differential gets above 0.5 even though the temp_diff sensor states ‘pending’.
Must be being switched on from somewhere else, that automation won’t fire if the sensor is pending. That’s the reason I introduced the pending state so I could add the condition.
Also, even if it did skip the condition somehow, unless the sensor is ‘pump_on’ then the result will be to switch off the pump.
So, if we’re happy it definitely was ‘pending’ it was switched on by some other means. If it was on pump_on I’ll need to have another look at the template.
Can you check the logbook and see which is the case?
Seems switching on and off OK, just not off when state is pending? There are no other automations pertaining to the solar_pump. Could the broker retain message be doing anything?
automation:
- id: ID12
alias: 'Pump hot water if hotter than pool - stop if not'
initial_state: 'on'
platform: state
entity_id: sensor.temp_diff
service_template: >
{% if is_state ('sensor.temp_diff' , 'pump_on') %} switch.turn_on
{% else %} switch.turn_off {% endif %}
I’ve just reordered the template to make sure it double checks if it should be off before it checks if it should be on, which will hopefully get rid of any false positives (should’ve done that in the first place, sorry!)
Then I’ve removed the condition to ensure that any state change that isn’t ‘pump_on’ switches it off. The automation will fire a little more frequently, but should ensure that the pump is always off when it should be.
Here is all three sensors. Nothing changed with those.
## Pool pump status sensor as switch is hidden:
sensors:
pool_pump_status:
value_template: '{% if is_state("switch.pool_pump", "on") %}Running{% else %}Stopped{% endif %}'
friendly_name: 'Pool Pump Status'
## Creates a history sensor based on how long the pool pump has been in a
## status of 'running' defined in the aboved value template:
- platform: history_stats
name: Pool Pump running today
entity_id: sensor.pool_pump_status
state: 'Running'
type: time
start: '{{ now().replace(hour=0).replace(minute=0).replace(second=0) }}'
end: '{{ now() }}'
## Look for the attribute named 'value' from the above sensor to create
## a new sensor using that attribute:
sensors:
pool_pump_time_on:
value_template: '{{ states.sensor.pool_pump_running_today.attributes.value }}'
friendly_name: 'Pool Pump Hours Running'
