I want to create a entity that I can toggle using a nfc tag.
Why that? So I can scan it when going to bed so it will first check if i’m asleep/in bed before turning on my lights when motion is detected.
What is the best way to obtain this?
I also want to use my google home to toggle the same state, is that easy too?
I get you want to know some state, but why NFC? So you can’t go to sleep because you need to charge your phone first? I use this to set an inut select helper for Home, Asleep, Away, Vacation, and I also have a sensor that detects if I’m in bed.
Single press (weekdays), put house in sleep mode (scene), set Alarm through Alexa on my nightstand Echo 8 and announce that it has done so, turn off final bedroom lights 2 minutes later… sleep.
Long Single press (weekends), put house in sleep mode, NO alarm set with Alexa, turn off last lights… sleep.
Double Press (every morning), cancel alarm through Alexa, announce local weather forecast… shower.
And there is obviously much more that can be added to the Automations, while my Android phone is already in its charging base by this point, so no need to scan NFC or anything.
The ‘toggle’ for ‘sleep mode’ you would do it as a boolean helper.
How you activate / deactivate it can be all of the above. NFC/buttons/automations/bed sensors/companion app sleep info.etc.
Personally I trigger mine with bed sensors… Its magical. Get in bed after X time (controlled by a datetime helper) and 30 seconds later the lights start to go down.
The switch is an ordinary Aqara Opple, the icons are just stickers I got a long time ago from Homewizard. You cannot buy them anymore there I’m afraid.
