Hello there! I’m very new here, please correct me if needed.
I have a Socomec Masterys BC+ UPS that I’d like to monitor with Homeassistant.
It exposes a simple XML structure with all the parameters so it was pretty easy to add all the sensors as below (I’m adding the configuration as it may help others):
rest:
- resource: http://10.50.0.140/xml/data.xml
- name: "UPS Output Lr"
value_template: "{{value_json.root.M.uM000}}"
unit_of_measurement: "%"
- name: "UPS Output S"
value_template: "{{value_json.root.M.uM004}}"
unit_of_measurement: "kVA"
device_class: apparent_power
- name: "UPS Output P"
value_template: "{{value_json.root.M.uM005}}"
unit_of_measurement: "kW"
device_class: power
- name: "UPS Output Lr1"
value_template: "{{value_json.root.M.uM001}}"
- name: "UPS Output Lr2"
value_template: "{{value_json.root.M.uM002}}"
- name: "UPS Output Lr3"
value_template: "{{value_json.root.M.uM003}}"
- name: "UPS Output S1"
value_template: "{{value_json.root.M.uM048}}"
- name: "UPS Output S2"
value_template: "{{value_json.root.M.uM049}}"
- name: "UPS Output S3"
value_template: "{{value_json.root.M.uM050}}"
- name: "UPS Output P1"
value_template: "{{value_json.root.M.uM051}}"
device_class: power
- name: "UPS Output P2"
value_template: "{{value_json.root.M.uM052}}"
device_class: power
- name: "UPS Output P3"
value_template: "{{value_json.root.M.uM053}}"
device_class: power
- name: "UPS Output V1"
value_template: "{{value_json.root.M.uM010}}"
unit_of_measurement: "V"
device_class: voltage
- name: "UPS Output V2"
value_template: "{{value_json.root.M.uM011}}"
- name: "UPS Output V3"
value_template: "{{value_json.root.M.uM012}}"
- name: "UPS Output U12"
value_template: "{{value_json.root.M.uM054}}"
- name: "UPS Output U23"
value_template: "{{value_json.root.M.uM055}}"
- name: "UPS Output U31"
value_template: "{{value_json.root.M.uM056}}"
- name: "UPS Output I1"
value_template: "{{value_json.root.M.uM006}}"
unit_of_measurement: "A"
device_class: current
- name: "UPS Output I2"
value_template: "{{value_json.root.M.uM007}}"
- name: "UPS Output I3"
value_template: "{{value_json.root.M.uM008}}"
- name: "UPS Output Fr"
value_template: "{{value_json.root.M.uM013}}"
unit_of_measurement: "Hz"
- name: "UPS Batt Vbat"
value_template: "{{value_json.root.M.uM016}}"
- name: "UPS Batt Ibat"
value_template: "{{value_json.root.M.uM018}}"
- name: "UPS Batt Temp"
value_template: "{{value_json.root.M.uM026}}"
unit_of_measurement: "°C"
device_class: temperature
- name: "UPS Batt Cap %"
value_template: "{{value_json.root.M.uM022}}"
- name: "UPS Batt Cap"
value_template: "{{value_json.root.M.uM023}}"
unit_of_measurement: "Ah"
- name: "UPS Batt BuT"
value_template: "{{value_json.root.M.uM024}}"
unit_of_measurement: "min"
- name: "UPS Input V1"
value_template: "{{value_json.root.M.uM033}}"
- name: "UPS Input V2"
- name: "UPS Input V3"
value_template: "{{value_json.root.M.uM034}}"
- name: "UPS Input U12"
value_template: "{{value_json.root.M.uM036}}"
- name: "UPS Input U23"
value_template: "{{value_json.root.M.uM037}}"
- name: "UPS Input U31"
value_template: "{{value_json.root.M.uM038}}"
- name: "UPS Input I1"
value_template: "{{value_json.root.M.uM064}}"
- name: "UPS Input I2"
value_template: "{{value_json.root.M.uM065}}"
- name: "UPS Input I3"
value_template: "{{value_json.root.M.uM066}}"
- name: "UPS Input P1"
value_template: "{{value_json.root.M.uM067}}"
device_class: power
- name: "UPS Input P2"
value_template: "{{value_json.root.M.uM068}}"
device_class: power
- name: "UPS Input P3"
value_template: "{{value_json.root.M.uM069}}"
device_class: power
- name: "UPS Input Fr"
value_template: "{{value_json.root.M.uM035}}"
device_class: frequency
- name: "UPS Bypass V1"
value_template: "{{value_json.root.M.uM039}}"
- name: "UPS Bypass V2"
value_template: "{{value_json.root.M.uM040}}"
- name: "UPS Bypass V3"
value_template: "{{value_json.root.M.uM041}}"
- name: "UPS Bypass U12"
value_template: "{{value_json.root.M.uM043}}"
- name: "UPS Bypass U23"
value_template: "{{value_json.root.M.uM044}}"
- name: "UPS Bypass U31"
value_template: "{{value_json.root.M.uM045}}"
- name: "UPS Bypass Fr"
value_template: "{{value_json.root.M.uM042}}"
I now would like to “group” these sensor in a single device called “UPS” or something, that I can put in some room just for cleanliness. How can I do that?
Thank you!
