My question has 2 parts. First is, how can I create a scene with specific brightness / temperature levels?
I am quite fresh to HA + YAML configuration. I have tried to first set up the scene with UI and then edit it in the YAML. However, there are no options to select temp/brightness in UI. I get something like this:
- id: '1673874192498'
entities:
light.olohuone_lipasto:
min_color_temp_kelvin: 2202
max_color_temp_kelvin: 6535
min_mireds: 153
max_mireds: 454
supported_color_modes:
- color_temp
mode: normal
dynamics: none
friendly_name: Lipasto
supported_features: 40
state: 'off'
How to add the custom brightness there?
If I google instructions I get suggestions like this:
- data:
entity_id: light.zooz_zen22_dimmer_v2_level
brightness_pct: 100
service: light.turn_on
These contain the “action” section.
And if I try to add this to my scene, I get error to the “id” level saying that: “property action is not allowed”.
So, how to actually create an automation which makes my lights to dim to a wanted state?
Thank you.
