I’m currently moving into a new place, and it turns out the only window in my room will be on a door (which also happens to be north facing). Of course I want a little more natural light- but that got me wondering if I can make a fake window that has the feel of natural light.
I found this tunable white LED panel which seems like a potential victim for this project.
It’s a little smaller than a normal window would be, but it is made to be a drop ceiling light, after all. I could put white electrical tape on the face of it to simulate some of the fancy bits you see on the glass of windows, build a little box around the sides to allow for clean mounting, and put a curtain in front of it. Somehow get it tied into Home Assistant, control the temperature with fluxer, make it dim based on the sun position (and possibly even make it change a little based on the weather!), and use a geofence to save power by turning it off when I’m not home.
The big question at hand is how to get it tied into Home Assistant. I’d probably have to ditch the built in controller/power supply, and then use a regular power supply and a controller that can connect to home assistant. I was thinking of using an H801, but you take a look at the panel’s built-in power solution, and I start to think the panel’s LED’s need more voltage than the H801 can handle.
As you can see, the power solution says it has an output of 27-48 volts; enough to nuke a poor little H801. HOWEVER, if you look further, it reads “0-10v / PWM / RX / RF Dimming”. That’s got me thinking that the actual LED’s are only being fed at most 10 volts, which an H801 would gladly handle.
Seeing how easily accessible the individual positive, warm, and cool wires are for the panel, I might just go ahead and buy it, and take some measurements from the provided controller.
I guess I’m more or less just posting to see if anybody here has any familiarity with a panel like this, and to document my adventure in making a fake window.
