Creating a template sensor For new weather method
My OpenHASP displays were all great until the last HA update where they changed the format. I’m not sure I fully understand the new method. The first thing I’m trying to get is the detailed forecast. I can create the service call and can see the info, but creating a template sensor is above my pay grade…
service: weather.get_forecasts
  entity_id:
    - weather.keul_daynight
  type: twice_daily
Results in this response. I want the detailed_description:
weather.keul_daynight:
  forecast:
    - detailed_description: Partly cloudy, with a low around 46. West wind around 9 mph.
      datetime: "2024-04-15T01:00:00-06:00"
      precipitation_probability: 0
      is_daytime: false
      condition: partlycloudy
      wind_bearing: 270
      temperature: 46
      dew_point: 40
      wind_speed: 9
      humidity: 74
    - detailed_description: >-
        Partly sunny, with a high near 66. West northwest wind 12 to 20 mph,
        with gusts as high as 29 mph.
      datetime: "2024-04-15T06:00:00-06:00"
Etc, etc, etc
So now I have to create a template sensor but this is where I’m stumbling. It will probably be something like this?
template:
  - trigger:
      - platform: time_pattern
        hours: /12              <-- is this right? 2x daily?
      - service: weather.get_forecasts
          type: twice_daily
          entity_id: weather.keul_daynight
        response_variable: hourly                 <--- what is this?
      - name: Detailed Description
        unique_id: detailed_description
        state: "{{ detailed['weather.home'].forecast[0].detailed }}" <- I'm am just guessing here...
If I can get it into a sensor I think I can figure out how to use it in HASP.
Anyone have any tips here?
         state: "{{ hourly['weather.keul_daynight'].forecast[0].detailed }}"
I got help on discord. This is the only way to do it apparently
- trigger:
      hours: /1
        type: twice_daily
      response_variable: detailed_description
    - name: KEUL Detailed Description
      unique_id: keul_detailed_description
      state: "{{ detailed_description['weather.keul_daynight'].forecast[0].detailed_description }}"
For those as confused as I was about this, whatever you use for response_variable: it needs to match in the sensor state: line in the sensor section.
Putting my special ring on helped a lot…
