Creating a way to track error counts from logger
Is there a way where I can create a way (i.e. sensor) that tracks the amount of errors that show up in the logs? Similar to the Watchman reporting tool that shows the volume of issues with entities (i.e. unavailable…).
I have defined a counter
counter:
    sys_log_counter:
      restore: false
And an automation that manages the counter based in events:
  - id: sys_log_counter
    alias: sys_log_counter
    mode: queued
      - platform: event
        event_type: system_log_event
        event_data:
          level: WARNING
      - platform: event
        event_data:
          level: ERROR
      - platform: event
        event_type: call_service
        event_data:
          domain: system_log
          service: clear
      - choose:
          - conditions: "{{ trigger.event.event_type == 'system_log_event' }}"
            sequence:
              - service: counter.increment
                  entity_id: counter.sys_log_counter
          - conditions: "{{ trigger.event.event_type == 'call_service' }}"
            sequence:
              - service: counter.reset
Awesome, thank you! Exactly what I was looking for
Thanks! This is great!
counter:
    sys_log_counter:
      restore: false
Where did you defined this counter? Inside the configuration.yaml?
I like the idea!
I did, but you can also do this in the gui > devices and services > helpers
“Restore the last known value when Home Assistant starts”
