Creating a YouTube Thumbnail Sensor in Home Assistant
Hello everyone.
When connected via AirPlay, the Apple TV integration in Home Assistant cannot retrieve the thumbnail of a YouTube video playing on the Apple TV’s YouTube app
I was searching for a solution to this issue when I came across matt8707’s project. youtube-watching
However, it did not work well in my environment, so I integrated it into AppDaemon.
It can be installed via HACS, and the MQTT integration is required. It’s easy to use.
You no longer need to use Appdaemon in a complicated way. Mattias Persson has provided us with an excellent solution.
However, I’ll keep maintaining the AppDaemon project for those who find the following setup difficult. Haha.
For Haos
  1. A cookies.txt file is still required.
  2. Your version of yt-dlp must be 2025.03.31 or later. Even if your Home Assistant core version is 2025.4.1, you still need to update it.
    2-1. Log in to the console window. It’s not an ssh addon or putty!
    2-2. Run login
    2-3. Run docker exec -it homeassistant /bin/bash
    2-4. Run pip install -U yt-dlp
    2-5. Run python3 -c "import yt_dlp; print(yt_dlp.version.__version__)"
    (Verify that the update is complete. If it outputs 2025.03.31, then it’s OK.)
  3. In the /config(homeassistant)/python(any folder name)/, create two files: youtube_thumbnail.py and set_entity_picture.py.
  4. Add the following to /config/secrets.yaml:
    ha_host: "http://{your_ha_ip}:8123"
    ha_token: "{your-long-lived-token}"
  5. Insert the following code into youtube_thumbnail.py:
import yt_dlp
import json
URL = "https://www.youtube.com/feed/history"
ydl_opts = {
   "cookiefile": "/config/python/.cookies.txt",
   "skip_download": True,
   "playlist_items": "1",
   "quiet": True,
   "no_warnings": True,
with yt_dlp.YoutubeDL(ydl_opts) as ydl:
   info = ydl.extract_info(URL, download=False)
   data = ydl.sanitize_info(info)
   entry = data.get("entries", [data])[0]
   print(
       json.dumps(
               "channel": entry.get("channel"),
               "title": entry.get("fulltitle"),
               "video_id": entry.get("id"),
               "thumbnail": entry.get("thumbnail"),
               "original_url": entry.get("original_url"),
           indent=2,
  1. Insert the following code into set_entity_picture.py:
    EDIT
    from secrets import get_secret did not work in the haos. It works successfully after loading the secrets.yaml file as shown below.
import argparse
import requests
import yaml
with open('/config/secrets.yaml') as f:
    secrets = yaml.safe_load(f)
HOST = get_secret("ha_host")
TOKEN = get_secret("ha_token")
def update_entity_picture(entity_id, entity_picture):
    url = f"{HOST}/api/states/{entity_id}"
    headers = {"Authorization": f"Bearer {TOKEN}", "Content-Type": "application/json"}
    response = requests.get(url, headers=headers)
    if response.status_code == 200:
        data = response.json()
        data["attributes"]["entity_picture"] = entity_picture
        response = requests.post(url, headers=headers, json=data)
            print("ok")
        else:
            print("Error posting update: ", response.text)
    else:
        print("Error retrieving state: ", response.text)
if __name__ == "__main__":
    parser = argparse.ArgumentParser(description="update entity_picture")
    parser.add_argument("--entity_id", required=True, help="entity_id")
    parser.add_argument("--entity_picture", required=True, help="entity_picture")
    args = parser.parse_args()
    update_entity_picture(args.entity_id, args.entity_picture)
  1. Add the following command_line sensor to /config/configuration.yaml:
command_line:
  - sensor:
      command: "python3 /config/python/youtube_thumbnail.py"
      value_template: "{{ value_json.thumbnail }}"
      json_attributes:
        - channel
        - title
        - video_id
        - thumbnail
        - original_url
      scan_interval: 86400
  1. Add the following shell_command to /config/configuration.yaml:
shell_command:
  set_entity_picture: "python3 /config/python/set_entity_picture.py --entity_id '{{ entity_id }}' --entity_picture '{{ entity_picture }}'"
  1. Create an automation.
alias: Set youtube entity_picture
triggers:
  - trigger: state
    entity_id:
      - media_player.sovrum
      - media_player.vardagsrum
    to:
      - playing
      - paused
conditions:
  - condition: template
    value_template: >
      {% set entity_id = trigger.entity_id %}
      {% set youtube = 'sensor.youtube_thumbnail' %}
      {{ is_state_attr(entity_id, 'app_id', 'com.google.ios.youtube')
      and (state_attr(entity_id, 'media_artist') != state_attr(youtube, 'channel'))
      and (state_attr(entity_id, 'media_title') != state_attr(youtube, 'title')) }}
actions:
  - action: homeassistant.update_entity
      entity_id:
        - sensor.youtube_thumbnail
  - action: shell_command.set_entity_picture
      entity_id: >
        {{ trigger.entity_id }}
      entity_picture: >
        {{ states('sensor.youtube_thumbnail') }}
mode: single
  1. It’s done. Now, when you play or pause the Apple TV, the media_player.apple_tv (used as a trigger in the automation) will have an entity_picture attribute.
Exactly what I was looking for. I’ve followed all the steps, but I can’t get the sensors to show up, they don’t exist. What do I need to do?
Show me what appears in the AppDaemon logs.
Hey, I’ve been playing with this again. Here’s what I’ve come up with so far
apperently yt_dlp is available in home assistant so just
import yt_dlp
import json
ydl_opts = {
    "quiet": True,
    print(
        json.dumps(
            indent=2,
and to “force” set entity_picture on the media player
import argparse
import requests
            print("ok")
        else:
    else:
triggers:
  - trigger: state
    entity_id:
    to:
      - playing
      - paused
conditions:
    value_template: >
actions:
      entity_id:
      entity_id: >
      entity_picture: >
mode: single
still some quirks, like pausing the media player will remove entity_picture, and because it’s not a session every yt fetch takes like 3 seconds. I’ve tried a container with GitHub - LuanRT/YouTube.js: A JavaScript client for YouTube's private API, known as InnerTube. and that is much faster
Nevermind, my AppDeamon was causing trouble. Got it working, trying to figure out how to get this code show up in my media conditional, still using Mattias old dashboard…
That’s great.
- type: conditional
  conditions:
    - entity: select.conditional_media
      state: 4k
  card:
    type: custom:button-card
    entity: media_player.4k
    triggers_update: sensor.youtube_watching
    template:
      - conditional_media
You should write it inside the dashboard’s media conditional. Of course, select.conditional_media must include the Apple TV entity. (Mine is media_player.4k)
I’m a huge fan of yours. I’ll try to understand the code you provided a bit more and leave my additional comments. EDIT The command_line isn’t working very well, though.
I have no idea how to execute this code,
import yt_dlp
import json
URL = “https://www.youtube.com/feed/history
ydl_opts = {
“cookiefile”: “/config/python/.cookies.txt”,
“skip_download”: True,
“playlist_items”: “1”,
“quiet”: True,
“no_warnings”: True,
entry = data.get(“entries”, [data])[0]
print(
json.dumps(
“channel”: entry.get(“channel”),
“title”: entry.get(“fulltitle”),
“video_id”: entry.get(“id”),
“thumbnail”: entry.get(“thumbnail”),
“original_url”: entry.get(“original_url”),
indent=2,
Fewww… I finally solved it. I was still using core 3.4, and the default installed version of yt-dlp was 2025.02.19. After updating yt-dlp to version 2025.3.31 in the console, it works correctly. In core 4.1, it’s version 2025.03.26.
But I still haven’t solved the import requests issue…
EDIT2
Alright. I’ve finally solved everything. Thank you so much
                  - type: conditional
                    conditions:
                        state: Vardagsrum
                    card:
                      entity: media_player.vardagsrum_2
                      template:
                        - conditional_media
                        - icon_apple_tv
                        - progress_bar
Not showing youtube thumbnail in conditional media grid place, but both mqtt sensors are working and giving correct data.
If so, you should take a look at the conditional_media template.
In fact, rather than focusing on conditional_media, you should take a closer look at the other included templates: base_media and media.
base_media
The is_youtube and entity_picture variables must be defined among the variables of the base_media template.
variables:
  media_on: >
    [[[ return !entity || ['playing', 'paused'].indexOf(entity.state) !== -1; ]]]
  media_off: >
    [[[ return !entity || ['off', 'idle', 'standby', 'unknown', 'unavailable'].indexOf(entity.state) !== -1; ]]]
  # entity_picture: >
  #   [[[ return !entity || entity.attributes.entity_picture; ]]]
  entity_picture: >
      if (!entity || entity.attributes.entity_picture === undefined) {
        return entity.attributes.title_image;
      return entity.attributes.entity_picture;
  is_youtube: >
      let is_youtube = entity?.attributes?.app_id === 'com.google.ios.youtube',
          sensor = this?._config?.triggers_update,
          media_title = entity?.attributes?.media_title,
          watching_title = states[sensor]?.attributes?.title;
      if (is_youtube && media_title === watching_title) {
          return true;
media
media:
  template:
    - base
    - base_media
styles:
    custom_fields:
      icon:
        - width: 70%
        - margin-left: 2%
        - fill: '#9da0a2'
        - display: >
            if (variables.is_youtube) {
                return `none`;
            else {
                return variables.media_off || variables.entity_picture === undefined
                    ? 'initial'
                    : 'none';
    card:
      - background-color: none
      - background-size: cover
      - background-position: center
      - background-image: >
                return `linear-gradient(0deg, rgba(0,0,0,.8) 0%, rgba(0,0,0,0) 100%), url(${states[this._config?.triggers_update].state})`;
            } else {
                return variables.media_on && variables.entity_picture === undefined
                    ? 'linear-gradient(0deg, rgba(255, 255, 255, 0.8) 0%, rgba(255, 255, 255, 0.8) 100%)'
                    : variables.media_off
                        ? 'linear-gradient(0deg, rgba(115, 115, 115, 0.2) 0%, rgba(115, 115, 115, 0.2) 100%)'
                        : `linear-gradient(0deg, rgba(0,0,0,.8) 0%, rgba(0,0,0,0) 100%), url(${variables.entity_picture})`;
conditional_media
conditional_media:
  aspect_ratio: 1000/996
  template:
    - base
    - base_media
    - icon_play_pause
  variables:
    i: >
        if (entity) {
            let data = entity.attributes.data;
            return data === undefined || Math.floor(Math.random() * (data.length - 1)) + 1;
  styles:
    card:
      - background: rgba(115, 115, 115, 0.2) center center/cover no-repeat
      # - background-image: &media_background_image >
            if (entity) {
                  return `url(${states[this._config?.triggers_update].state})`;
              } else {
                return data && (data[variables.i].fanart || data[variables.i].poster)
                    ? `url("${data[variables.i].fanart}"), url("${data[variables.i].poster}")`
                    : `url("${variables.entity_picture}")`;
Since I made a number of modifications from the original, there may be some differences.
how did you solve secret problem? i got this error?
ImportError: cannot import name ‘get_secret’ from ‘secrets’
(/usr/local/lib/python3.13/secrets.py)
Look at item number 6. The file /config/secret.yaml must contain the ha_token and ha_host entries.
import yaml
that solves it. But when i use it i get following response.
However, last week when i tried first, youtube watching (getting image) sensor was working. now it doesnt anymore. I get following error in the log.
Command failed (with return code 1): python3 << EOF import yt_dlp import json URL = "https://www.youtube.com/feed/history" ydl_opts = { "cookiefile": "/config/youtube_cookies.txt", "skip_download": True, "playlist_items": "1", "quiet": True, "no_warnings": True, } with yt_dlp.YoutubeDL(ydl_opts) as ydl: info = ydl.extract_info(URL, download=False) data = ydl.sanitize_info(info) entry = data.get("entries", [data])[0] print( json.dumps( { "channel": entry.get("channel"), "title": entry.get("fulltitle"), "video_id": entry.get("id"), "thumbnail": entry.get("thumbnail"), "original_url": entry.get("original_url"), }, indent=2, ) ) EOF
I used the python code in my laptop, it works. that means cookies file is valid still. but within HA it isnt working.
Hi, kind regards.
I know this is probably a lot to ask, but I’m still new to Home Assistant. I’d love to see the yt thumbnails on my dashboard—would you mind making a clear guide, easy to follow, on how to set it up? I can kofee you to thank you for your time.
Thanks, have a nice day.
