I want to put a button on the dashboard, and when I select it, different things would happen. Lights go off, roller shutter go down, etc.
Since I’m using the GUI editor, what would be the appropriate way to do so?
You may want to take a look at Scenes Editor
hello
first create the boutton (input_boolean) in ‘helpers’ and put it with a ‘button-card’ in ‘overview’ (lovelace-ui)
then create an automation with your button as trigger and shutter, lights…(and why not scripts or scenes) in actions
voila
If you mean your homeassistant dashboard (ie on a screen), then you could just write the automation (or a script) and then have a button on a card which triggers the automation (or executes the script) when it is pressed.
If you mean your car dashboard - you need to integrate the button (depends on what it is) !
This seems the way to go, I’m having a look on the GUI, but I don’t see a way to trigger a specific action.
Do I have to change the configuration.yaml manually?
I’m using this but I’m getting and error say that extra keys are not allowed
type: button
tap_action:
action: call-service
service: automation.trigger
service_data:
entity: automation.abrir_estores_sala_2
