Creating an Automation that activates an inching relay at a set time for a set period
What have you done so far? How to help us help you - or How to ask a good question
I’m sure that can be done. Also having someone or something writing it for you means the second it misbehaves, you will be struggling back to find someone to fix it for you.
The best way to learn is to just try. Run thru the docs on getting started with the automation editor. If you get stuck, come back with what you have done.
Understanding automations - Home Assistant
and
The Home Assistant Cookbook - Index.
