An input_array type integration for numeric or string values is similar to the imput_number integration.
Input_select?
Hey,
It would take an input_array integration that works like a pyhton array Python Arrays (w3schools.com)
Entity attributes can hold array types.
What exactly are you trying to do?
What problem are you trying to solve?
Hey,
In an automation, I need to memorize an atmospheric pressure value every full hour. For this I use 24 input_number in the following way
alias: Memo Pressions
description: “”
- platform: time_pattern
hours: “*”
condition: []
action: - service: input_number.set_value
value: “{{ states(“input_number.histopress23”) }}”
entity_id: input_number.histopress24 - service: input_number.set_value
value: “{{ states(“input_number.histopress22”) }}”
entity_id: input_number.histopress23 - service: input_number.set_value
value: “{{ states(“input_number.histopress21”) }}”
entity_id: input_number.histopress22 - service: input_number.set_value
value: “{{ states(“input_number.histopress20”) }}”
entity_id: input_number.histopress21 - service: input_number.set_value
value: “{{ states(“input_number.histopress19”) }}”
entity_id: input_number.histopress20 - service: input_number.set_value
value: “{{ states(“input_number.histopress18”) }}”
entity_id: input_number.histopress19 - service: input_number.set_value
value: “{{ states(“input_number.histopress17”) }}”
entity_id: input_number.histopress18 - service: input_number.set_value
value: “{{ states(“input_number.histopress16”) }}”
entity_id: input_number.histopress17 - service: input_number.set_value
value: “{{ states(“input_number.histopress15”) }}”
entity_id: input_number.histopress16 - service: input_number.set_value
value: “{{ states(“input_number.histopress14”) }}”
entity_id: input_number.histopress15 - service: input_number.set_value
value: “{{ states(“input_number.histopress13”) }}”
entity_id: input_number.histopress14 - service: input_number.set_value
value: “{{ states(“input_number.histopress12”) }}”
entity_id: input_number.histopress13 - service: input_number.set_value
value: “{{ states(“input_number.histopress11”) }}”
entity_id: input_number.histopress12 - service: input_number.set_value
value: “{{ states(“input_number.histopress10”) }}”
entity_id: input_number.histopress11 - service: input_number.set_value
value: “{{ states(“input_number.histopress9”) }}”
entity_id: input_number.histopress10 - service: input_number.set_value
value: “{{ states(“input_number.histopress8”) }}”
entity_id: input_number.histopress9 - service: input_number.set_value
value: “{{ states(“input_number.histopress7”) }}”
entity_id: input_number.histopress8 - service: input_number.set_value
value: “{{ states(“input_number.histopress6”) }}”
entity_id: input_number.histopress7 - service: input_number.set_value
value: “{{ states(“input_number.histopress5”) }}”
entity_id: input_number.histopress6 - service: input_number.set_value
value: “{{ states(“input_number.histopress4”) }}”
entity_id: input_number.histopress5 - service: input_number.set_value
value: “{{ states(“input_number.histopress3”) }}”
entity_id: input_number.histopress4 - service: input_number.set_value
value: “{{ states(“input_number.histopress2”) }}”
entity_id: input_number.histopress3 - service: input_number.set_value
value: “{{ states(“input_number.histopress1”) }}”
entity_id: input_number.histopress2 - service: input_number.set_value
value: “{{ states(“input_number.histopress0”) }}”
entity_id: input_number.histopress1 - service: input_number.set_value
value: “{{ states(“sensor.relative_pressure”) }}”
entity_id: input_number.histopress0
mode: single
If I had the option of having an input_array, I would just create a single input entity of size 24 and use a For Loop to store the values into it.
You could write a JSON string into an input_text helper.
{% set input_text = "[4,6,1,9,8,3]" %}
Input text: "{{ input_text }}"
{% set array = input_text|from_json %}
Array: {{ array }}
{% set new_pressure = 7 %}
{% set array = array[1:] + [new_pressure] %}
Updated array: {{ array }}
{% set input_text = array|to_json %}
Updated input text: "{{ input_text }}"
You can do this by creating a single sensor with 24 attributes,
If I understood you correctly, you have 24 Input Numbers representing a record of the last 24 values of sensor.relative_pressure recorded at one-hour intervals.
I know how to do this with a single Trigger-based Template Sensor (and its value and attributes aren’t lost after a restart). However, what do you do with these 24 values?
Example
The following Trigger-based Template Sensor records the value of sensor.relative_pressure every hour and stores it, and the time when it was recorded, in a list within an attribute named hourly_pressure. The attribute maintains a record of the last 24 pressure readings (older values are discarded).
template:
- trigger:
hours: '*'
- name: Atmospheric Pressure
state: "{{ now().timestamp() | timestamp_custom() }}"
attributes:
hourly_pressure: >
{% set current = this.attributes.get('hourly_pressure', []) %}
{% set new = [{
"pressure": states('sensor.relative_pressure') | default (0),
"time": now().isoformat() }] %}
{{ (new + current)[:24] }}
Hey 123 Taras,
I use them in a weather prediction algorithm on my HASS. I also transfer them in an MQTT push for another device.
Thank for you help.
In that case, the Trigger-based Template Sensor I posted above should do everything you require.
To publish the sensor’s 24 pressure values to MQTT, you can do it like this:
- service: mqtt.publish
topic: your/topic
payload_template: >
{{ state_attr('sensor.atmospheric_pressure', 'hourly_pressure')
| map(attribute='pressure') | list }}
The 24 pressure values are in order of newest to oldest. If you want them in the opposite order, just use the reverse filter
payload_template: >
| map(attribute='pressure') | reverse | list }}
Hey 123 Taras,
Great, thanks, it works great. Would it be possible to complete “pressure”: with an index incremented from 1 to 24 to give “pressure1”:, “pressure2”:, …, “pressure24”:.
There’s no need to do that. The value of the hourly_pressure attribute is a list. Lists are indexed starting with the number zero.
For example, this reports the first, second, and last pressure values in the list.
{% set x = state_attr('sensor.atmospheric_pressure', 'hourly_pressure') %}
{{ x[0] }}
{{ x[1] }}
{{ x[-1] }}
Hey 123 Taras,
Everything works perfectly.
Thank you for your help.
Sorry to revive an old thread, but does this survive a HA restart?
Because it’s Trigger-based Template Sensor.
