Creating backup keeps spinning
Using the internal backup tool, I get errors that they didn’t complete but they still show up in the backups. While creating backup, it keeps spinning and doesn’t finish
2025-02-13 10:31:10.573 INFO (MainThread) [supervisor.mounts.manager] Reloading mount: Unraid
2025-02-13 10:31:10.636 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2025-02-13 10:31:10.636 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-02-13 10:31:10.636 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2025-02-13 10:31:10.819 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2025-02-13 10:31:10.819 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2025-02-13 10:31:10.824 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-02-13 10:31:10.824 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2025-02-13 10:31:10.825 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2025-02-13 10:31:10.825 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2025-02-13 10:31:10.825 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2025-02-13 10:31:10.826 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2025-02-13 10:31:10.826 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-02-13 10:31:10.826 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-02-13 10:31:10.967 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-02-13 10:31:10.967 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2025-02-13 10:31:10.967 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2025-02-13 10:31:48.690 ERROR (MainThread) [supervisor.homeassistant.core] No Home Assistant Core response, assuming a fatal startup error
2025-02-13 10:31:48.691 INFO (MainThread) [supervisor.resolution.module] Create new issue update_failed - core / None
2025-02-13 10:32:13.951 INFO (MainThread) [supervisor.backups.manager] Backup 56ca65ca starting stage addon_repositories
2025-02-13 10:32:13.952 INFO (MainThread) [supervisor.backups.manager] Creating new partial backup with slug 56ca65ca
2025-02-13 10:32:13.992 INFO (MainThread) [supervisor.backups.manager] Backup 56ca65ca starting stage home_assistant
2025-02-13 10:32:14.013 INFO (MainThread) [supervisor.homeassistant.module] Backing up Home Assistant Core config folder
2025-02-13 10:33:00.577 INFO (MainThread) [supervisor.homeassistant.module] Backup Home Assistant Core config folder done
2025-02-13 10:33:00.580 INFO (MainThread) [supervisor.backups.manager] Backup 56ca65ca starting stage addons
2025-02-13 10:33:00.618 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_matter_server
2025-02-13 10:33:00.888 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_matter_server
2025-02-13 10:33:00.910 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_mosquitto
2025-02-13 10:33:00.915 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_mosquitto
2025-02-13 10:33:00.940 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on 03cabcc9_ring_mqtt
2025-02-13 10:33:00.951 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon 03cabcc9_ring_mqtt
2025-02-13 10:33:00.992 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_samba
2025-02-13 10:33:01.019 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_samba
2025-02-13 10:33:01.048 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on 9074a9fa_cloudflared
2025-02-13 10:33:01.056 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon 9074a9fa_cloudflared
2025-02-13 10:33:01.084 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_configurator
2025-02-13 10:33:01.095 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_configurator
2025-02-13 10:33:01.119 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_aircast
2025-02-13 10:33:01.126 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_aircast
2025-02-13 10:33:01.151 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_rpc_shutdown
2025-02-13 10:33:01.155 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_rpc_shutdown
2025-02-13 10:33:01.184 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_adguard
2025-02-13 10:33:01.238 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_adguard
2025-02-13 10:33:01.262 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on d5369777_music_assistant
2025-02-13 10:33:02.467 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon d5369777_music_assistant
2025-02-13 10:33:02.491 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on 5c53de3b_esphome
2025-02-13 10:33:02.496 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon 5c53de3b_esphome
2025-02-13 10:33:02.520 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on b9845f46_govee2mqtt
2025-02-13 10:33:02.589 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon b9845f46_govee2mqtt
2025-02-13 10:33:02.613 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_ssh
2025-02-13 10:33:02.624 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_ssh
2025-02-13 10:33:02.625 INFO (MainThread) [supervisor.backups.manager] Backup 56ca65ca starting stage folders
2025-02-13 10:33:02.626 INFO (SyncWorker_0) [supervisor.backups.backup] Backing up folder ssl
2025-02-13 10:33:02.638 INFO (SyncWorker_0) [supervisor.backups.backup] Backup folder ssl done
2025-02-13 10:33:02.638 INFO (MainThread) [supervisor.backups.manager] Backup 56ca65ca starting stage finishing_file
2025-02-13 10:33:03.303 INFO (MainThread) [supervisor.backups.manager] Creating partial backup with slug 56ca65ca completed
2025-02-13 10:36:19.474 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2025-02-13 10:36:19.474 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-02-13 10:36:19.474 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2025-02-13 10:36:19.475 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2025-02-13 10:36:19.476 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2025-02-13 10:36:19.482 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-02-13 10:36:19.482 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2025-02-13 10:36:19.482 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2025-02-13 10:36:19.483 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2025-02-13 10:36:19.483 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2025-02-13 10:36:19.483 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2025-02-13 10:36:19.483 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-02-13 10:36:19.483 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-02-13 10:36:19.636 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-02-13 10:36:19.637 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2025-02-13 10:36:19.637 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
Thanks for any assistance, running on proxmox.
@dontdoititoldyou I have the same problem, have you found a solution?
No solution. I’ve disabled backups in HA and just using proxmox backups.
I’m afraid there is something fundamentally wrong with my installation and need to start fresh. Hope not though.
I have the same problem on two seperate HA installs. Manual backups complete, but it seems Supervisor never informs HA. Only other clue that may be related is the following I just saw in the Supervisor log:
ERROR (MainThread) [supervisor.homeassistant.corel No Home Assistant Core response, assuming a fatal startup error
Do you guys see this as well?
Yes I do remember seeing that error.
Have you tried restoring from the backup? Mine fails.
I haven’t tried restoring. Just assuming it finished correctly from the log and entry in the back up list. Both of my installs are VMs running HAOS. Are you using HAOS?
Yeah, HAOS. I tried a new machine and the restore process worked but getting the same issue, except now the backup was only 70MB while on the old machine, it was a GB
In the end my problem was having http.server_host set which you can’t use with an install using Supervisor (HAOS or Docker Supervised). I wanted to limit the IP the UI was running on to just a VLAN interface that gets proxied via NGINX. But then Supervisor can’t reach it via the Docker interface it assumes it’s available on. So if you’re using that setting removing it should help.
As for the backup size, I’m guessing it didn’t include some of your history/stats maybe?
Thanks, I also have server_host set so as to allow me to add devices on a serperate vlan without needing to set up an mDNS repeater as I can’t get it working with pfsense
Worked! wow…crazy such a little setting can make me pull my hair out lol
solution above
Necroing this old thread as the issue still exists and in my case http.server_host has never been set so that is not a solution for me.
I have TBs available on the SMB NAS I am sending the files so it is not a space issue.
What seems to have worked for me is to exclude all add-ons with the exception of MariaDB. The major exclusions are the Matter server and Mosquito Broker.
