Restarted appdaemon, set to debug level. Went to main panel then back to status panel where the two widgets are, the custom weather widget named tplink and your inconsensor widget. Default Skin for test same results with Dark1.
2018-04-07 13:06:32.523108 DEBUG HADasboard: Found dashboard type Control Panel
2018-04-07 13:06:32.526474 DEBUG HADasboard: Found dashboard type Status
2018-04-07 13:06:32.654762 DEBUG AppDaemon: Event type:state_changed:
2018-04-07 13:06:32.655596 DEBUG AppDaemon: {'entity_id': 'switch.garage_miner', 'old_state': {'entity_id': 'switch.garage_miner', 'state': 'on', 'attributes': {'current_power_w': '884.20', 'total_energy_kwh': '135.823', 'voltage': '113.8', 'current_a': '7.78', 'today_energy_kwh': '11.739', 'friendly_name': 'Garage Miner'}, 'last_changed': '2018-04-07T00:12:49.599266+00:00', 'last_updated': '2018-04-07T17:06:01.335463+00:00'}, 'new_state': {'entity_id': 'switch.garage_miner', 'state': 'on', 'attributes': {'current_power_w': '884.53', 'total_energy_kwh': '135.830', 'voltage': '113.7', 'current_a': '7.78', 'today_energy_kwh': '11.746', 'friendly_name': 'Garage Miner'}, 'last_changed': '2018-04-07T00:12:49.599266+00:00', 'last_updated': '2018-04-07T17:06:32.591602+00:00'}}
2018-04-07 13:06:32.657060 DEBUG AppDaemon: {'entity_id': 'switch.garage_miner', 'old_state': {'entity_id': 'switch.garage_miner', 'state': 'on', 'attributes': {'current_power_w': '884.20', 'total_energy_kwh': '135.823', 'voltage': '113.8', 'current_a': '7.78', 'today_energy_kwh': '11.739', 'friendly_name': 'Garage Miner'}, 'last_changed': '2018-04-07T00:12:49.599266+00:00', 'last_updated': '2018-04-07T17:06:01.335463+00:00'}, 'new_state': {'entity_id': 'switch.garage_miner', 'state': 'on', 'attributes': {'current_power_w': '884.53', 'total_energy_kwh': '135.830', 'voltage': '113.7', 'current_a': '7.78', 'today_energy_kwh': '11.746', 'friendly_name': 'Garage Miner'}, 'last_changed': '2018-04-07T00:12:49.599266+00:00', 'last_updated': '2018-04-07T17:06:32.591602+00:00'}}
2018-04-07 13:06:32.659591 DEBUG HADasboard: Sending data to 2 dashes: {'event_type': 'state_changed', 'data': {'entity_id': 'switch.garage_miner', 'old_state': {'entity_id': 'switch.garage_miner', 'state': 'on', 'attributes': {'current_power_w': '884.20', 'total_energy_kwh': '135.823', 'voltage': '113.8', 'current_a': '7.78', 'today_energy_kwh': '11.739', 'friendly_name': 'Garage Miner'}, 'last_changed': '2018-04-07T00:12:49.599266+00:00', 'last_updated': '2018-04-07T17:06:01.335463+00:00'}, 'new_state': {'entity_id': 'switch.garage_miner', 'state': 'on', 'attributes': {'current_power_w': '884.53', 'total_energy_kwh': '135.830', 'voltage': '113.7', 'current_a': '7.78', 'today_energy_kwh': '11.746', 'friendly_name': 'Garage Miner'}, 'last_changed': '2018-04-07T00:12:49.599266+00:00', 'last_updated': '2018-04-07T17:06:32.591602+00:00'}}, 'origin': 'LOCAL', 'time_fired': '2018-04-07T17:06:32.591724+00:00'}
2018-04-07 13:06:32.661043 DEBUG HADasboard: Found dashboard type Control Panel
2018-04-07 13:06:32.662770 DEBUG HADasboard: Found dashboard type Status
2018-04-07 13:06:32.678654 DEBUG AppDaemon: Event type:state_changed:
2018-04-07 13:06:32.679381 DEBUG AppDaemon: {'entity_id': 'sensor.tp_link_watts', 'old_state': {'entity_id': 'sensor.tp_link_watts', 'state': '884.2', 'attributes': {'unit_of_measurement': 'W', 'friendly_name': 'Watts'}, 'last_changed': '2018-04-07T17:06:01.383020+00:00', 'last_updated': '2018-04-07T17:06:01.383020+00:00'}, 'new_state': {'entity_id': 'sensor.tp_link_watts', 'state': '884.53', 'attributes': {'unit_of_measurement': 'W', 'friendly_name': 'Watts'}, 'last_changed': '2018-04-07T17:06:32.607562+00:00', 'last_updated': '2018-04-07T17:06:32.607562+00:00'}}
2018-04-07 13:06:32.680712 DEBUG AppDaemon: {'entity_id': 'sensor.tp_link_watts', 'old_state': {'entity_id': 'sensor.tp_link_watts', 'state': '884.2', 'attributes': {'unit_of_measurement': 'W', 'friendly_name': 'Watts'}, 'last_changed': '2018-04-07T17:06:01.383020+00:00', 'last_updated': '2018-04-07T17:06:01.383020+00:00'}, 'new_state': {'entity_id': 'sensor.tp_link_watts', 'state': '884.53', 'attributes': {'unit_of_measurement': 'W', 'friendly_name': 'Watts'}, 'last_changed': '2018-04-07T17:06:32.607562+00:00', 'last_updated': '2018-04-07T17:06:32.607562+00:00'}}
2018-04-07 13:06:32.681866 DEBUG HADasboard: Sending data to 2 dashes: {'event_type': 'state_changed', 'data': {'entity_id': 'sensor.tp_link_watts', 'old_state': {'entity_id': 'sensor.tp_link_watts', 'state': '884.2', 'attributes': {'unit_of_measurement': 'W', 'friendly_name': 'Watts'}, 'last_changed': '2018-04-07T17:06:01.383020+00:00', 'last_updated': '2018-04-07T17:06:01.383020+00:00'}, 'new_state': {'entity_id': 'sensor.tp_link_watts', 'state': '884.53', 'attributes': {'unit_of_measurement': 'W', 'friendly_name': 'Watts'}, 'last_changed': '2018-04-07T17:06:32.607562+00:00', 'last_updated': '2018-04-07T17:06:32.607562+00:00'}}, 'origin': 'LOCAL', 'time_fired': '2018-04-07T17:06:32.607709+00:00'}
2018-04-07 13:06:32.683522 DEBUG HADasboard: Found dashboard type Control Panel
2018-04-07 13:06:32.685202 DEBUG HADasboard: Found dashboard type Status
2018-04-07 13:06:32.695625 DEBUG AppDaemon: Event type:state_changed:
2018-04-07 13:06:32.696449 DEBUG AppDaemon: {'entity_id': 'sensor.tp_link_kw', 'old_state': {'entity_id': 'sensor.tp_link_kw', 'state': '135.823', 'attributes': {'unit_of_measurement': 'kWh', 'friendly_name': 'Current KiloWatts'}, 'last_changed': '2018-04-07T17:06:01.409657+00:00', 'last_updated': '2018-04-07T17:06:01.409657+00:00'}, 'new_state': {'entity_id': 'sensor.tp_link_kw', 'state': '135.83', 'attributes': {'unit_of_measurement': 'kWh', 'friendly_name': 'Current KiloWatts'}, 'last_changed': '2018-04-07T17:06:32.619582+00:00', 'last_updated': '2018-04-07T17:06:32.619582+00:00'}}
2018-04-07 13:06:32.697573 DEBUG AppDaemon: {'entity_id': 'sensor.tp_link_kw', 'old_state': {'entity_id': 'sensor.tp_link_kw', 'state': '135.823', 'attributes': {'unit_of_measurement': 'kWh', 'friendly_name': 'Current KiloWatts'}, 'last_changed': '2018-04-07T17:06:01.409657+00:00', 'last_updated': '2018-04-07T17:06:01.409657+00:00'}, 'new_state': {'entity_id': 'sensor.tp_link_kw', 'state': '135.83', 'attributes': {'unit_of_measurement': 'kWh', 'friendly_name': 'Current KiloWatts'}, 'last_changed': '2018-04-07T17:06:32.619582+00:00', 'last_updated': '2018-04-07T17:06:32.619582+00:00'}}
2018-04-07 13:06:32.698988 DEBUG HADasboard: Sending data to 2 dashes: {'event_type': 'state_changed', 'data': {'entity_id': 'sensor.tp_link_kw', 'old_state': {'entity_id': 'sensor.tp_link_kw', 'state': '135.823', 'attributes': {'unit_of_measurement': 'kWh', 'friendly_name': 'Current KiloWatts'}, 'last_changed': '2018-04-07T17:06:01.409657+00:00', 'last_updated': '2018-04-07T17:06:01.409657+00:00'}, 'new_state': {'entity_id': 'sensor.tp_link_kw', 'state': '135.83', 'attributes': {'unit_of_measurement': 'kWh', 'friendly_name': 'Current KiloWatts'}, 'last_changed': '2018-04-07T17:06:32.619582+00:00', 'last_updated': '2018-04-07T17:06:32.619582+00:00'}}, 'origin': 'LOCAL', 'time_fired': '2018-04-07T17:06:32.619700+00:00'}
2018-04-07 13:06:32.700497 DEBUG HADasboard: Found dashboard type Control Panel
2018-04-07 13:06:32.702480 DEBUG HADasboard: Found dashboard type Status
2018-04-07 13:06:32.714312 DEBUG AppDaemon: Event type:state_changed:
2018-04-07 13:06:32.714942 DEBUG AppDaemon: {'entity_id': 'sensor.tp_link_kw_today', 'old_state': {'entity_id': 'sensor.tp_link_kw_today', 'state': '11.739', 'attributes': {'unit_of_measurement': 'kWh', 'friendly_name': "Today's KiloWatts"}, 'last_changed': '2018-04-07T17:06:01.431641+00:00', 'last_updated': '2018-04-07T17:06:01.431641+00:00'}, 'new_state': {'entity_id': 'sensor.tp_link_kw_today', 'state': '11.746', 'attributes': {'unit_of_measurement': 'kWh', 'friendly_name': "Today's KiloWatts"}, 'last_changed': '2018-04-07T17:06:32.629069+00:00', 'last_updated': '2018-04-07T17:06:32.629069+00:00'}}
2018-04-07 13:06:32.716126 DEBUG AppDaemon: {'entity_id': 'sensor.tp_link_kw_today', 'old_state': {'entity_id': 'sensor.tp_link_kw_today', 'state': '11.739', 'attributes': {'unit_of_measurement': 'kWh', 'friendly_name': "Today's KiloWatts"}, 'last_changed': '2018-04-07T17:06:01.431641+00:00', 'last_updated': '2018-04-07T17:06:01.431641+00:00'}, 'new_state': {'entity_id': 'sensor.tp_link_kw_today', 'state': '11.746', 'attributes': {'unit_of_measurement': 'kWh', 'friendly_name': "Today's KiloWatts"}, 'last_changed': '2018-04-07T17:06:32.629069+00:00', 'last_updated': '2018-04-07T17:06:32.629069+00:00'}}
2018-04-07 13:06:32.717867 DEBUG HADasboard: Sending data to 2 dashes: {'event_type': 'state_changed', 'data': {'entity_id': 'sensor.tp_link_kw_today', 'old_state': {'entity_id': 'sensor.tp_link_kw_today', 'state': '11.739', 'attributes': {'unit_of_measurement': 'kWh', 'friendly_name': "Today's KiloWatts"}, 'last_changed': '2018-04-07T17:06:01.431641+00:00', 'last_updated': '2018-04-07T17:06:01.431641+00:00'}, 'new_state': {'entity_id': 'sensor.tp_link_kw_today', 'state': '11.746', 'attributes': {'unit_of_measurement': 'kWh', 'friendly_name': "Today's KiloWatts"}, 'last_changed': '2018-04-07T17:06:32.629069+00:00', 'last_updated': '2018-04-07T17:06:32.629069+00:00'}}, 'origin': 'LOCAL', 'time_fired': '2018-04-07T17:06:32.629353+00:00'}
2018-04-07 13:06:32.719825 DEBUG HADasboard: Found dashboard type Control Panel
2018-04-07 13:06:32.722060 DEBUG HADasboard: Found dashboard type Status
2018-04-07 13:06:32.731745 DEBUG AppDaemon: Event type:state_changed:
2018-04-07 13:06:32.736747 DEBUG AppDaemon: {'entity_id': 'sensor.tp_link_volts', 'old_state': {'entity_id': 'sensor.tp_link_volts', 'state': '113.8', 'attributes': {'unit_of_measurement': 'V', 'friendly_name': 'Current Voltage'}, 'last_changed': '2018-04-07T17:06:01.450715+00:00', 'last_updated': '2018-04-07T17:06:01.450715+00:00'}, 'new_state': {'entity_id': 'sensor.tp_link_volts', 'state': '113.7', 'attributes': {'unit_of_measurement': 'V', 'friendly_name': 'Current Voltage'}, 'last_changed': '2018-04-07T17:06:32.636501+00:00', 'last_updated': '2018-04-07T17:06:32.636501+00:00'}}
2018-04-07 13:06:32.737676 DEBUG AppDaemon: {'entity_id': 'sensor.tp_link_volts', 'old_state': {'entity_id': 'sensor.tp_link_volts', 'state': '113.8', 'attributes': {'unit_of_measurement': 'V', 'friendly_name': 'Current Voltage'}, 'last_changed': '2018-04-07T17:06:01.450715+00:00', 'last_updated': '2018-04-07T17:06:01.450715+00:00'}, 'new_state': {'entity_id': 'sensor.tp_link_volts', 'state': '113.7', 'attributes': {'unit_of_measurement': 'V', 'friendly_name': 'Current Voltage'}, 'last_changed': '2018-04-07T17:06:32.636501+00:00', 'last_updated': '2018-04-07T17:06:32.636501+00:00'}}
2018-04-07 13:06:32.739054 DEBUG HADasboard: Sending data to 2 dashes: {'event_type': 'state_changed', 'data': {'entity_id': 'sensor.tp_link_volts', 'old_state': {'entity_id': 'sensor.tp_link_volts', 'state': '113.8', 'attributes': {'unit_of_measurement': 'V', 'friendly_name': 'Current Voltage'}, 'last_changed': '2018-04-07T17:06:01.450715+00:00', 'last_updated': '2018-04-07T17:06:01.450715+00:00'}, 'new_state': {'entity_id': 'sensor.tp_link_volts', 'state': '113.7', 'attributes': {'unit_of_measurement': 'V', 'friendly_name': 'Current Voltage'}, 'last_changed': '2018-04-07T17:06:32.636501+00:00', 'last_updated': '2018-04-07T17:06:32.636501+00:00'}}, 'origin': 'LOCAL', 'time_fired': '2018-04-07T17:06:32.636681+00:00'}
2018-04-07 13:06:32.740419 DEBUG HADasboard: Found dashboard type Control Panel
2018-04-07 13:06:32.742587 DEBUG HADasboard: Found dashboard type Status
2018-04-07 13:06:32.999458 DEBUG AppDaemon: Util loop compute time: 5.0ms
2018-04-07 13:06:33.006321 DEBUG AppDaemon: Scheduler loop compute time: 4.0ms
2018-04-07 13:06:34.005108 DEBUG AppDaemon: Scheduler loop compute time: 1.0ms
2018-04-07 13:06:34.009612 DEBUG AppDaemon: Util loop compute time: 3.0ms
2018-04-07 13:06:35.006042 DEBUG AppDaemon: Scheduler loop compute time: 3.0ms
2018-04-07 13:06:35.016156 DEBUG AppDaemon: Util loop compute time: 4.0ms
2018-04-07 13:06:36.006152 DEBUG AppDaemon: Scheduler loop compute time: 3.0ms
2018-04-07 13:06:36.025905 DEBUG AppDaemon: Util loop compute time: 4.0ms
2018-04-07 13:06:37.008012 DEBUG AppDaemon: Scheduler loop compute time: 4.0ms
2018-04-07 13:06:37.034655 DEBUG AppDaemon: Util loop compute time: 4.0ms
2018-04-07 13:06:38.006744 DEBUG AppDaemon: Scheduler loop compute time: 3.0ms
2018-04-07 13:06:38.042580 DEBUG AppDaemon: Util loop compute time: 4.0ms
2018-04-07 13:06:39.007431 DEBUG AppDaemon: Scheduler loop compute time: 4.0ms
2018-04-07 13:06:39.051949 DEBUG AppDaemon: Util loop compute time: 4.0ms
2018-04-07 13:06:40.007500 DEBUG AppDaemon: Scheduler loop compute time: 4.0ms
2018-04-07 13:06:40.060188 DEBUG AppDaemon: Util loop compute time: 5.0ms
2018-04-07 13:06:41.004281 DEBUG AppDaemon: Scheduler loop compute time: 1.0ms
2018-04-07 13:06:41.066307 DEBUG AppDaemon: Util loop compute time: 3.0ms
2018-04-07 13:06:41.085578 DEBUG AppDaemon: Event type:state_changed:
2018-04-07 13:06:41.086463 DEBUG AppDaemon: {'entity_id': 'sensor.load_5m', 'old_state': {'entity_id': 'sensor.load_5m', 'state': '0.68505859375', 'attributes': {'unit_of_measurement': ' ', 'friendly_name': 'Load (5m)', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:10.335568+00:00', 'last_updated': '2018-04-07T17:06:10.335568+00:00'}, 'new_state': {'entity_id': 'sensor.load_5m', 'state': '0.69921875', 'attributes': {'unit_of_measurement': ' ', 'friendly_name': 'Load (5m)', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:41.040901+00:00', 'last_updated': '2018-04-07T17:06:41.040901+00:00'}}
2018-04-07 13:06:41.087664 DEBUG AppDaemon: {'entity_id': 'sensor.load_5m', 'old_state': {'entity_id': 'sensor.load_5m', 'state': '0.68505859375', 'attributes': {'unit_of_measurement': ' ', 'friendly_name': 'Load (5m)', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:10.335568+00:00', 'last_updated': '2018-04-07T17:06:10.335568+00:00'}, 'new_state': {'entity_id': 'sensor.load_5m', 'state': '0.69921875', 'attributes': {'unit_of_measurement': ' ', 'friendly_name': 'Load (5m)', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:41.040901+00:00', 'last_updated': '2018-04-07T17:06:41.040901+00:00'}}
2018-04-07 13:06:41.089210 DEBUG HADasboard: Sending data to 2 dashes: {'event_type': 'state_changed', 'data': {'entity_id': 'sensor.load_5m', 'old_state': {'entity_id': 'sensor.load_5m', 'state': '0.68505859375', 'attributes': {'unit_of_measurement': ' ', 'friendly_name': 'Load (5m)', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:10.335568+00:00', 'last_updated': '2018-04-07T17:06:10.335568+00:00'}, 'new_state': {'entity_id': 'sensor.load_5m', 'state': '0.69921875', 'attributes': {'unit_of_measurement': ' ', 'friendly_name': 'Load (5m)', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:41.040901+00:00', 'last_updated': '2018-04-07T17:06:41.040901+00:00'}}, 'origin': 'LOCAL', 'time_fired': '2018-04-07T17:06:41.041014+00:00'}
2018-04-07 13:06:41.092020 DEBUG HADasboard: Found dashboard type Control Panel
2018-04-07 13:06:41.094351 DEBUG HADasboard: Found dashboard type Status
2018-04-07 13:06:41.123543 DEBUG AppDaemon: Event type:state_changed:
2018-04-07 13:06:41.125516 DEBUG AppDaemon: {'entity_id': 'sensor.load_1m', 'old_state': {'entity_id': 'sensor.load_1m', 'state': '0.744140625', 'attributes': {'unit_of_measurement': ' ', 'friendly_name': 'Load (1m)', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:10.242844+00:00', 'last_updated': '2018-04-07T17:06:10.242844+00:00'}, 'new_state': {'entity_id': 'sensor.load_1m', 'state': '0.79736328125', 'attributes': {'unit_of_measurement': ' ', 'friendly_name': 'Load (1m)', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:41.085001+00:00', 'last_updated': '2018-04-07T17:06:41.085001+00:00'}}
2018-04-07 13:06:41.127188 DEBUG AppDaemon: {'entity_id': 'sensor.load_1m', 'old_state': {'entity_id': 'sensor.load_1m', 'state': '0.744140625', 'attributes': {'unit_of_measurement': ' ', 'friendly_name': 'Load (1m)', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:10.242844+00:00', 'last_updated': '2018-04-07T17:06:10.242844+00:00'}, 'new_state': {'entity_id': 'sensor.load_1m', 'state': '0.79736328125', 'attributes': {'unit_of_measurement': ' ', 'friendly_name': 'Load (1m)', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:41.085001+00:00', 'last_updated': '2018-04-07T17:06:41.085001+00:00'}}
2018-04-07 13:06:41.129763 DEBUG HADasboard: Sending data to 2 dashes: {'event_type': 'state_changed', 'data': {'entity_id': 'sensor.load_1m', 'old_state': {'entity_id': 'sensor.load_1m', 'state': '0.744140625', 'attributes': {'unit_of_measurement': ' ', 'friendly_name': 'Load (1m)', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:10.242844+00:00', 'last_updated': '2018-04-07T17:06:10.242844+00:00'}, 'new_state': {'entity_id': 'sensor.load_1m', 'state': '0.79736328125', 'attributes': {'unit_of_measurement': ' ', 'friendly_name': 'Load (1m)', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:41.085001+00:00', 'last_updated': '2018-04-07T17:06:41.085001+00:00'}}, 'origin': 'LOCAL', 'time_fired': '2018-04-07T17:06:41.085141+00:00'}
2018-04-07 13:06:41.132078 DEBUG HADasboard: Found dashboard type Control Panel
2018-04-07 13:06:41.138239 DEBUG HADasboard: Found dashboard type Status
2018-04-07 13:06:41.154149 DEBUG AppDaemon: Event type:state_changed:
2018-04-07 13:06:41.154778 DEBUG AppDaemon: {'entity_id': 'sensor.processor_use', 'old_state': {'entity_id': 'sensor.processor_use', 'state': '15', 'attributes': {'unit_of_measurement': '%', 'friendly_name': 'Processor use', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:10.130033+00:00', 'last_updated': '2018-04-07T17:06:10.130033+00:00'}, 'new_state': {'entity_id': 'sensor.processor_use', 'state': '16', 'attributes': {'unit_of_measurement': '%', 'friendly_name': 'Processor use', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:41.122042+00:00', 'last_updated': '2018-04-07T17:06:41.122042+00:00'}}
2018-04-07 13:06:41.155655 DEBUG AppDaemon: {'entity_id': 'sensor.processor_use', 'old_state': {'entity_id': 'sensor.processor_use', 'state': '15', 'attributes': {'unit_of_measurement': '%', 'friendly_name': 'Processor use', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:10.130033+00:00', 'last_updated': '2018-04-07T17:06:10.130033+00:00'}, 'new_state': {'entity_id': 'sensor.processor_use', 'state': '16', 'attributes': {'unit_of_measurement': '%', 'friendly_name': 'Processor use', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:41.122042+00:00', 'last_updated': '2018-04-07T17:06:41.122042+00:00'}}
2018-04-07 13:06:41.156887 DEBUG HADasboard: Sending data to 2 dashes: {'event_type': 'state_changed', 'data': {'entity_id': 'sensor.processor_use', 'old_state': {'entity_id': 'sensor.processor_use', 'state': '15', 'attributes': {'unit_of_measurement': '%', 'friendly_name': 'Processor use', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:10.130033+00:00', 'last_updated': '2018-04-07T17:06:10.130033+00:00'}, 'new_state': {'entity_id': 'sensor.processor_use', 'state': '16', 'attributes': {'unit_of_measurement': '%', 'friendly_name': 'Processor use', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:41.122042+00:00', 'last_updated': '2018-04-07T17:06:41.122042+00:00'}}, 'origin': 'LOCAL', 'time_fired': '2018-04-07T17:06:41.122153+00:00'}
2018-04-07 13:06:41.159360 DEBUG HADasboard: Found dashboard type Control Panel
2018-04-07 13:06:41.161723 DEBUG HADasboard: Found dashboard type Status
2018-04-07 13:06:41.258852 DEBUG AppDaemon: Event type:state_changed:
2018-04-07 13:06:41.260043 DEBUG AppDaemon: {'entity_id': 'sensor.load_15m', 'old_state': {'entity_id': 'sensor.load_15m', 'state': '0.638671875', 'attributes': {'unit_of_measurement': ' ', 'friendly_name': 'Load (15m)', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:10.389078+00:00', 'last_updated': '2018-04-07T17:06:10.389078+00:00'}, 'new_state': {'entity_id': 'sensor.load_15m', 'state': '0.64404296875', 'attributes': {'unit_of_measurement': ' ', 'friendly_name': 'Load (15m)', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:41.173215+00:00', 'last_updated': '2018-04-07T17:06:41.173215+00:00'}}
2018-04-07 13:06:41.263797 DEBUG AppDaemon: {'entity_id': 'sensor.load_15m', 'old_state': {'entity_id': 'sensor.load_15m', 'state': '0.638671875', 'attributes': {'unit_of_measurement': ' ', 'friendly_name': 'Load (15m)', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:10.389078+00:00', 'last_updated': '2018-04-07T17:06:10.389078+00:00'}, 'new_state': {'entity_id': 'sensor.load_15m', 'state': '0.64404296875', 'attributes': {'unit_of_measurement': ' ', 'friendly_name': 'Load (15m)', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:41.173215+00:00', 'last_updated': '2018-04-07T17:06:41.173215+00:00'}}
2018-04-07 13:06:41.267425 DEBUG HADasboard: Sending data to 2 dashes: {'event_type': 'state_changed', 'data': {'entity_id': 'sensor.load_15m', 'old_state': {'entity_id': 'sensor.load_15m', 'state': '0.638671875', 'attributes': {'unit_of_measurement': ' ', 'friendly_name': 'Load (15m)', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:10.389078+00:00', 'last_updated': '2018-04-07T17:06:10.389078+00:00'}, 'new_state': {'entity_id': 'sensor.load_15m', 'state': '0.64404296875', 'attributes': {'unit_of_measurement': ' ', 'friendly_name': 'Load (15m)', 'icon': 'mdi:memory'}, 'last_changed': '2018-04-07T17:06:41.173215+00:00', 'last_updated': '2018-04-07T17:06:41.173215+00:00'}}, 'origin': 'LOCAL', 'time_fired': '2018-04-07T17:06:41.173334+00:00'}
2018-04-07 13:06:41.269978 DEBUG HADasboard: Found dashboard type Control Panel
2018-04-07 13:06:41.274641 DEBUG HADasboard: Found dashboard type Status
2018-04-07 13:06:41.335910 DEBUG AppDaemon: Event type:state_changed:
2018-04-07 13:06:41.337295 DEBUG AppDaemon: {'entity_id': 'sensor.since_last_boot', 'old_state': {'entity_id': 'sensor.since_last_boot', 'state': '16:54:49.058426', 'attributes': {'unit_of_measurement': '', 'friendly_name': 'Since last boot', 'icon': 'mdi:clock'}, 'last_changed': '2018-04-07T17:06:10.082091+00:00', 'last_updated': '2018-04-07T17:06:10.082091+00:00'}, 'new_state': {'entity_id': 'sensor.since_last_boot', 'state': '16:55:20.267417', 'attributes': {'unit_of_measurement': '', 'friendly_name': 'Since last boot', 'icon': 'mdi:clock'}, 'last_changed': '2018-04-07T17:06:41.294840+00:00', 'last_updated': '2018-04-07T17:06:41.294840+00:00'}}
2018-04-07 13:06:41.338804 DEBUG AppDaemon: {'entity_id': 'sensor.since_last_boot', 'old_state': {'entity_id': 'sensor.since_last_boot', 'state': '16:54:49.058426', 'attributes': {'unit_of_measurement': '', 'friendly_name': 'Since last boot', 'icon': 'mdi:clock'}, 'last_changed': '2018-04-07T17:06:10.082091+00:00', 'last_updated': '2018-04-07T17:06:10.082091+00:00'}, 'new_state': {'entity_id': 'sensor.since_last_boot', 'state': '16:55:20.267417', 'attributes': {'unit_of_measurement': '', 'friendly_name': 'Since last boot', 'icon': 'mdi:clock'}, 'last_changed': '2018-04-07T17:06:41.294840+00:00', 'last_updated': '2018-04-07T17:06:41.294840+00:00'}}
2018-04-07 13:06:41.340637 DEBUG HADasboard: Sending data to 2 dashes: {'event_type': 'state_changed', 'data': {'entity_id': 'sensor.since_last_boot', 'old_state': {'entity_id': 'sensor.since_last_boot', 'state': '16:54:49.058426', 'attributes': {'unit_of_measurement': '', 'friendly_name': 'Since last boot', 'icon': 'mdi:clock'}, 'last_changed': '2018-04-07T17:06:10.082091+00:00', 'last_updated': '2018-04-07T17:06:10.082091+00:00'}, 'new_state': {'entity_id': 'sensor.since_last_boot', 'state': '16:55:20.267417', 'attributes': {'unit_of_measurement': '', 'friendly_name': 'Since last boot', 'icon': 'mdi:clock'}, 'last_changed': '2018-04-07T17:06:41.294840+00:00', 'last_updated': '2018-04-07T17:06:41.294840+00:00'}}, 'origin': 'LOCAL', 'time_fired': '2018-04-07T17:06:41.295041+00:00'}
2018-04-07 13:06:41.342527 DEBUG HADasboard: Found dashboard type Control Panel
2018-04-07 13:06:41.345189 DEBUG HADasboard: Found dashboard type Status
2018-04-07 13:06:42.006522 DEBUG AppDaemon: Scheduler loop compute time: 3.0ms
2018-04-07 13:06:42.073946 DEBUG AppDaemon: Util loop compute time: 4.0ms
2018-04-07 13:06:42.625094 DEBUG AppDaemon: Event type:state_changed:
2018-04-07 13:06:42.625828 DEBUG AppDaemon: {'entity_id': 'sensor.music_listening_this_week_lounge', 'old_state': {'entity_id': 'sensor.music_listening_this_week_lounge', 'state': '15.32', 'attributes': {'value': '15h 18m', 'unit_of_measurement': 'h', 'friendly_name': 'Music Listening This Week Lounge', 'icon': 'mdi:chart-line'}, 'last_changed': '2018-04-07T17:06:12.296994+00:00', 'last_updated': '2018-04-07T17:06:12.296994+00:00'}, 'new_state': {'entity_id': 'sensor.music_listening_this_week_lounge', 'state': '15.32', 'attributes': {'value': '15h 19m', 'unit_of_measurement': 'h', 'friendly_name': 'Music Listening This Week Lounge', 'icon': 'mdi:chart-line'}, 'last_changed': '2018-04-07T17:06:12.296994+00:00', 'last_updated': '2018-04-07T17:06:42.579598+00:00'}}
2018-04-07 13:06:42.631008 DEBUG AppDaemon: {'entity_id': 'sensor.music_listening_this_week_lounge', 'old_state': {'entity_id': 'sensor.music_listening_this_week_lounge', 'state': '15.32', 'attributes': {'value': '15h 18m', 'unit_of_measurement': 'h', 'friendly_name': 'Music Listening This Week Lounge', 'icon': 'mdi:chart-line'}, 'last_changed': '2018-04-07T17:06:12.296994+00:00', 'last_updated': '2018-04-07T17:06:12.296994+00:00'}, 'new_state': {'entity_id': 'sensor.music_listening_this_week_lounge', 'state': '15.32', 'attributes': {'value': '15h 19m', 'unit_of_measurement': 'h', 'friendly_name': 'Music Listening This Week Lounge', 'icon': 'mdi:chart-line'}, 'last_changed': '2018-04-07T17:06:12.296994+00:00', 'last_updated': '2018-04-07T17:06:42.579598+00:00'}}
2018-04-07 13:06:42.634942 DEBUG HADasboard: Sending data to 2 dashes: {'event_type': 'state_changed', 'data': {'entity_id': 'sensor.music_listening_this_week_lounge', 'old_state': {'entity_id': 'sensor.music_listening_this_week_lounge', 'state': '15.32', 'attributes': {'value': '15h 18m', 'unit_of_measurement': 'h', 'friendly_name': 'Music Listening This Week Lounge', 'icon': 'mdi:chart-line'}, 'last_changed': '2018-04-07T17:06:12.296994+00:00', 'last_updated': '2018-04-07T17:06:12.296994+00:00'}, 'new_state': {'entity_id': 'sensor.music_listening_this_week_lounge', 'state': '15.32', 'attributes': {'value': '15h 19m', 'unit_of_measurement': 'h', 'friendly_name': 'Music Listening This Week Lounge', 'icon': 'mdi:chart-line'}, 'last_changed': '2018-04-07T17:06:12.296994+00:00', 'last_updated': '2018-04-07T17:06:42.579598+00:00'}}, 'origin': 'LOCAL', 'time_fired': '2018-04-07T17:06:42.580161+00:00'}
2018-04-07 13:06:42.640438 DEBUG HADasboard: Found dashboard type Control Panel
2018-04-07 13:06:42.641990 DEBUG HADasboard: Found dashboard type Status
2018-04-07 13:06:43.006232 DEBUG AppDaemon: Scheduler loop compute time: 3.0ms
2018-04-07 13:06:43.081468 DEBUG AppDaemon: Util loop compute time: 4.0ms
2018-04-07 13:06:44.004140 DEBUG AppDaemon: Scheduler loop compute time: 1.0ms
2018-04-07 13:06:44.088816 DEBUG AppDaemon: Util loop compute time: 4.0ms
2018-04-07 13:06:45.007159 DEBUG AppDaemon: Scheduler loop compute time: 4.0ms
2018-04-07 13:06:45.095402 DEBUG AppDaemon: Util loop compute time: 4.0ms
2018-04-07 13:06:46.006556 DEBUG AppDaemon: Scheduler loop compute time: 3.0ms
2018-04-07 13:06:46.102870 DEBUG AppDaemon: Util loop compute time: 4.0ms
2018-04-07 13:06:47.006916 DEBUG AppDaemon: Scheduler loop compute time: 3.0ms
2018-04-07 13:06:47.112956 DEBUG AppDaemon: Util loop compute time: 6.0ms
2018-04-07 13:06:48.006818 DEBUG AppDaemon: Scheduler loop compute time: 4.0ms
2018-04-07 13:06:48.122708 DEBUG AppDaemon: Util loop compute time: 4.0ms
