Hi, I am needing assistance… I am so close i think. I have transitioned to using docker_monitor custom component. I have added tls connections which are working great. The last leg of my transition is to create a service, that will allow restarting containers (ultimately i want it so i can restart the home-assistant container). I added the code and it works, however i am getting this traceback on hass start.
I have placed comments in the code to identify my changes and provide a means of identifying where the problem lies. Any assistance would be awesome!
Exception in thread Thread-21:
File "/usr/local/lib/python3.7/threading.py", line 926, in _bootstrap_inner
self.run()
File "/usr/local/lib/python3.7/threading.py", line 870, in run
self._target(*self._args, **self._kwargs)
File "/config/custom_components/docker_monitor/__init__.py", line 460, in _runnable
self._notify(stats)
File "/config/custom_components/docker_monitor/__init__.py", line 355, in _notify
callback(message)
File "/config/custom_components/docker_monitor/sensor.py", line 231, in update_callback
self.schedule_update_ha_state()
File "/usr/src/app/homeassistant/helpers/entity.py", line 339, in schedule_update_ha_state
self.hass.add_job(self.async_update_ha_state(force_refresh))
AttributeError: 'NoneType' object has no attribute 'add_job'
This is the current _init_.py
Docker Monitor component
For more details about this component, please refer to the documentation at
https://github.com/Sanderhuisman/home-assistant-custom-components
import logging
import threading
import time
from datetime import timedelta
import homeassistant.helpers.config_validation as cv
import voluptuous as vol
from homeassistant.const import (
ATTR_ATTRIBUTION,
ATTR_NAME,
CONF_MONITORED_CONDITIONS,
CONF_NAME,
CONF_SCAN_INTERVAL,
CONF_URL,
EVENT_HOMEASSISTANT_STOP
from homeassistant.core import callback
from homeassistant.helpers.discovery import load_platform
from homeassistant.util import slugify as util_slugify
VERSION = '0.0.3'
REQUIREMENTS = ['docker==3.7.0', 'python-dateutil==2.7.5']
_LOGGER = logging.getLogger(__name__)
DOMAIN = 'docker_monitor'
CONF_ATTRIBUTION = 'Data provided by Docker'
DOCKER_HANDLE = 'docker_handle'
DATA_DOCKER_API = 'api'
DATA_CONFIG = 'config'
EVENT_CONTAINER = 'container_event'
PRECISION = 2
DEFAULT_URL = 'unix://var/run/docker.sock'
DEFAULT_NAME = 'Docker'
DEFAULT_SCAN_INTERVAL = timedelta(seconds=10)
DOCKER_TYPE = [
'sensor',
'switch'
CONF_EVENTS = 'events'
CONF_CONTAINERS = 'containers'
# Added for TLS
CONF_TLS_CA = 'tls_ca'
CONF_TLS_CERT = 'tls_cert'
CONF_TLS_KEY = 'tls_key'
UTILISATION_MONITOR_VERSION = 'utilization_version'
CONTAINER_MONITOR_STATUS = 'container_status'
CONTAINER_MONITOR_UPTIME = 'container_uptime'
CONTAINER_MONITOR_IMAGE = 'container_image'
CONTAINER_MONITOR_CPU_PERCENTAGE = 'container_cpu_percentage_usage'
CONTAINER_MONITOR_MEMORY_USAGE = 'container_memory_usage'
CONTAINER_MONITOR_MEMORY_PERCENTAGE = 'container_memory_percentage_usage'
CONTAINER_MONITOR_NETWORK_SPEED_UP = 'container_network_speed_up'
CONTAINER_MONITOR_NETWORK_SPEED_DOWN = 'container_network_speed_down'
CONTAINER_MONITOR_NETWORK_TOTAL_UP = 'container_network_total_up'
CONTAINER_MONITOR_NETWORK_TOTAL_DOWN = 'container_network_total_down'
_UTILISATION_MON_COND = {
UTILISATION_MONITOR_VERSION: ['Version', None, 'mdi:information-outline', None],
_CONTAINER_MON_COND = {
CONTAINER_MONITOR_STATUS: ['Status', None, 'mdi:checkbox-marked-circle-outline', None],
CONTAINER_MONITOR_UPTIME: ['Up Time', '', 'mdi:clock', 'timestamp'],
CONTAINER_MONITOR_IMAGE: ['Image', None, 'mdi:information-outline', None],
CONTAINER_MONITOR_CPU_PERCENTAGE: ['CPU use', '%', 'mdi:chip', None],
CONTAINER_MONITOR_MEMORY_USAGE: ['Memory use', 'MB', 'mdi:memory', None],
CONTAINER_MONITOR_MEMORY_PERCENTAGE: ['Memory use (percent)', '%', 'mdi:memory', None],
CONTAINER_MONITOR_NETWORK_SPEED_UP: ['Network speed Up', 'kB/s', 'mdi:upload', None],
CONTAINER_MONITOR_NETWORK_SPEED_DOWN: ['Network speed Down', 'kB/s', 'mdi:download', None],
CONTAINER_MONITOR_NETWORK_TOTAL_UP: ['Network total Up', 'MB', 'mdi:upload', None],
CONTAINER_MONITOR_NETWORK_TOTAL_DOWN: ['Network total Down', 'MB', 'mdi:download', None],
_MONITORED_CONDITIONS = \
list(_UTILISATION_MON_COND.keys()) + \
list(_CONTAINER_MON_COND.keys())
CONFIG_SCHEMA = vol.Schema({
DOMAIN: vol.Schema({
vol.Optional(CONF_NAME, default=DEFAULT_NAME):
cv.string,
vol.Optional(CONF_URL, default=DEFAULT_URL):
cv.string,
vol.Optional(CONF_TLS_CA, default=None):
cv.string,
vol.Optional(CONF_TLS_CERT, default=None):
cv.string,
vol.Optional(CONF_TLS_KEY, default=None):
cv.string,
vol.Optional(CONF_SCAN_INTERVAL, default=DEFAULT_SCAN_INTERVAL):
cv.time_period,
vol.Optional(CONF_EVENTS, default=False):
cv.boolean,
vol.Optional(CONF_MONITORED_CONDITIONS, default=_MONITORED_CONDITIONS):
vol.All(cv.ensure_list, [vol.In(_MONITORED_CONDITIONS)]),
vol.Optional(CONF_CONTAINERS):
cv.ensure_list,
}, extra=vol.ALLOW_EXTRA)
def setup(hass, config):
_LOGGER.info("Settings: {}".format(config[DOMAIN]))
host = config[DOMAIN].get(CONF_URL)
# Added for TLS
tls_ca = config[DOMAIN].get(CONF_TLS_CA)
tls_cert = config[DOMAIN].get(CONF_TLS_CERT)
tls_key = config[DOMAIN].get(CONF_TLS_KEY)
tls = [tls_ca, tls_cert, tls_key]
try:
api = DockerAPI(host, tls)
except (ImportError, ConnectionError) as e:
_LOGGER.info("Error setting up Docker API ({})".format(e))
return False
else:
version = api.get_info()
_LOGGER.debug("Docker version: {}".format(
version.get('version', None)))
hass.data[DOCKER_HANDLE] = {}
hass.data[DOCKER_HANDLE][DATA_DOCKER_API] = api
hass.data[DOCKER_HANDLE][DATA_CONFIG] = {
CONF_NAME: config[DOMAIN][CONF_NAME],
CONF_CONTAINERS: config[DOMAIN].get(CONF_CONTAINERS, [container.get_name() for container in api.get_containers()]),
CONF_MONITORED_CONDITIONS: config[DOMAIN].get(CONF_MONITORED_CONDITIONS),
CONF_SCAN_INTERVAL: config[DOMAIN].get(CONF_SCAN_INTERVAL),
for component in DOCKER_TYPE:
load_platform(hass, component, DOMAIN, {}, config)
def monitor_stop(_service_or_event):
"""Stop the monitor thread."""
_LOGGER.info("Stopping threads for Docker monitor")
api.exit()
hass.bus.listen_once(EVENT_HOMEASSISTANT_STOP, monitor_stop)
def event_listener(message):
event = util_slugify("{} {}".format(config[DOMAIN][CONF_NAME], EVENT_CONTAINER))
_LOGGER.debug("Sending event {} notification with message {}".format(event, message))
hass.bus.fire(event, message)
if config[DOMAIN][CONF_EVENTS]:
api.events(event_listener)
# Added for restart service. With this, every start of hass has a traceback.
def handle_restart(call):
"""Handle the service call."""
api.restart(call)
hass.services.register(DOMAIN, 'restart', handle_restart)
return True
Docker API abstraction
class DockerAPI:
def __init__(self, base_url, tls):
self._base_url = base_url
# Added for TLS
self._tls_ca = tls[0]
self._tls_cert = tls[1]
self._tls_key = tls[2]
try:
import docker
except ImportError as e:
_LOGGER.error("Missing Docker library ({})".format(e))
raise ImportError()
self._containers = {}
self._event_callback_listeners = []
self._events = None
# Added for TLS
if self._tls_ca is not None and self._tls_cert is not None and self._tls_key is not None:
tls_config = docker.tls.TLSConfig(
verify=True,
ca_cert=self._tls_ca,
client_cert=(
self._tls_cert,
self._tls_key
else:
tls_config=False
try:
self._client = docker.DockerClient(base_url=self._base_url, tls=tls_config)
except Exception as e:
_LOGGER.error("Can not connect to Docker ({})".format(e))
raise ConnectionError()
for container in self._client.containers.list(all=True) or []:
_LOGGER.debug("Found container: {}".format(container.name))
self._containers[container.name] = DockerContainerAPI(
self._client, container.name)
def exit(self):
if self._events:
self._events.close()
for container in self._containers.values():
container.exit()
def events(self, callback):
if not self._event_callback_listeners:
thread = threading.Thread(target=self._runnable, kwargs={})
thread.start()
if callback not in self._event_callback_listeners:
self._event_callback_listeners.append(callback)
def get_info(self):
version = {}
try:
raw_stats = self._client.version()
version = {
'version': raw_stats.get('Version', None),
'api_version': raw_stats.get('ApiVersion', None),
'os': raw_stats.get('Os', None),
'arch': raw_stats.get('Arch', None),
'kernel': raw_stats.get('KernelVersion', None),
_LOGGER.error("Cannot get Docker version ({})".format(e))
return version
def _runnable(self):
self._events = self._client.events(decode=True)
for event in self._events:
_LOGGER.debug("Event: ({})".format(event))
try:
# Only interested in container events
if event['Type'] == 'container':
message = {
'Container': event['Actor']['Attributes'].get('name'),
'Image': event['from'],
'Status': event['status'],
'Id': event['id'],
_LOGGER.info("Container event: ({})".format(message))
for callback in self._event_callback_listeners:
callback(message)
except KeyError as e:
_LOGGER.error("Key error: ({})".format(e))
pass
def get_containers(self):
return list(self._containers.values())
def get_container(self, name):
container = None
if name in self._containers:
container = self._containers[name]
return container
# I've tried this as a separate function as well.
def restart(self, call):
name = call.data.get(ATTR_NAME, DEFAULT_NAME)
try:
_LOGGER.debug("Restarting {} docker container.".format(name))
container = self.get_container(name)
container.restart()
except:
_LOGGER.warn("{}.restart service failed for {} container.".format(DOMAIN, name))
class DockerContainerAPI:
def __init__(self, client, name):
self._client = client
self._name = name
self._subscribers = []
self._container = client.containers.get(self._name)
self._thread = None
self._stopper = None
def get_name(self):
return self._name
# Call from DockerAPI
def exit(self, timeout=None):
"""Stop the thread."""
_LOGGER.debug("Close stats thread for container {}".format(self._name))
if self._thread is not None:
self._stopper.set()
def stats(self, callback, interval=10):
if not self._subscribers:
self._stopper = threading.Event()
'interval': interval})
self._thread = thread
thread.start()
if callback not in self._subscribers:
self._subscribers.append(callback)
def get_info(self):
from dateutil import parser
self._container.reload()
info = {
'id': self._container.id,
'image': self._container.image.tags,
'status': self._container.attrs['State']['Status'],
'created': parser.parse(self._container.attrs['Created']),
'started': parser.parse(self._container.attrs['State']['StartedAt']),
return info
def start(self):
_LOGGER.info("Start container {}".format(self._name))
self._container.start()
def stop(self, timeout=10):
_LOGGER.info("Stop container {}".format(self._name))
self._container.stop(timeout=timeout)
def restart(self):
_LOGGER.info("REstart container {}".format(self._name))
self._container.restart()
def _notify(self, message):
_LOGGER.debug("Send notify for container {}".format(self._name))
for callback in self._subscribers:
callback(message)
def _runnable(self, interval):
stream = self._container.stats(stream=True, decode=True)
cpu_old = {}
network_old = {}
for raw in stream:
if self._stopper.isSet():
break
stats = {}
stats['info'] = self.get_info()
if stats['info']['status'] in ('running', 'paused'):
stats['read'] = parser.parse(raw['read'])
cpu_stats = {}
try:
cpu_new = {}
cpu_new['total'] = raw['cpu_stats']['cpu_usage']['total_usage']
cpu_new['system'] = raw['cpu_stats']['system_cpu_usage']
# Compatibility wih older Docker API
if 'online_cpus' in raw['cpu_stats']:
cpu_stats['online_cpus'] = raw['cpu_stats']['online_cpus']
else:
cpu_stats['online_cpus'] = len(
raw['cpu_stats']['cpu_usage']['percpu_usage'] or [])
# raw do not have CPU information
_LOGGER.info("Cannot grab CPU usage for container {} ({})".format(
self._container.id, e))
_LOGGER.debug(raw)
else:
if cpu_old:
cpu_delta = float(cpu_new['total'] - cpu_old['total'])
system_delta = float(
cpu_new['system'] - cpu_old['system'])
cpu_stats['total'] = round(0.0, PRECISION)
if cpu_delta > 0.0 and system_delta > 0.0:
(cpu_delta / system_delta) * float(cpu_stats['online_cpus']) * 100.0, PRECISION)
cpu_old = cpu_new
memory_stats = {}
try:
memory_stats['usage'] = raw['memory_stats']['usage']
memory_stats['limit'] = raw['memory_stats']['limit']
memory_stats['max_usage'] = raw['memory_stats']['max_usage']
except (KeyError, TypeError) as e:
# raw_stats do not have MEM information
_LOGGER.info("Cannot grab MEM usage for container {} ({})".format(
_LOGGER.debug(raw)
else:
memory_stats['usage_percent'] = round(
float(memory_stats['usage']) / float(memory_stats['limit']) * 100.0, PRECISION)
network_stats = {}
try:
network_new = {}
_LOGGER.debug("Found network stats: {}".format(raw["networks"]))
network_stats['total_tx'] = 0
network_stats['total_rx'] = 0
for if_name, data in raw["networks"].items():
_LOGGER.debug("Stats for interface {} -> up {} / down {}".format(
if_name, data["tx_bytes"], data["rx_bytes"]))
network_stats['total_tx'] += data["tx_bytes"]
network_stats['total_rx'] += data["rx_bytes"]
network_new = {
'read': stats['read'],
'total_tx': network_stats['total_tx'],
'total_rx': network_stats['total_rx'],
# raw_stats do not have NETWORK information
_LOGGER.info("Cannot grab NET usage for container {} ({})".format(
_LOGGER.debug(raw)
else:
if network_old:
tx = network_new['total_tx'] - network_old['total_tx']
rx = network_new['total_rx'] - network_old['total_rx']
tim = (network_new['read'] - network_old['read']).total_seconds()
network_stats['speed_tx'] = round(float(tx) / tim, PRECISION)
network_stats['speed_rx'] = round(float(rx) / tim, PRECISION)
network_old = network_new
stats['cpu'] = cpu_stats
stats['memory'] = memory_stats
stats['network'] = network_stats
else:
stats['cpu'] = {}
stats['memory'] = {}
stats['network'] = {}
self._notify(stats)
time.sleep(interval)
