Creating Group of Power Points
I’m wanting to create a group of power points that I have and have tried to follow the guidance here:
HA Groups
However, I get as far as typing in “group::” in configuration.yaml and the file editor shows an error.
Can someone please offer some guidance on this?
Yes, because you have two times a “:”
Can you please show your full configuration.yaml file? Is it possible that you have group: already somewhere else in configuration.yaml? What error do you get?
Hi. The double “::” was a typo in the post.
My config file is currently this:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
config:
frontend:
  themes: !include_dir_merge_named themes
device_tracker:
  - platform: bt_smarthub
    smarthub_model: 2
homeassistant:
  customize: !include customize.yaml
camera:
  - platform: ffmpeg
    input: rtsp://[email protected]:[email protected]:554/stream1
light:
  - platform: group
    entities:
    - light.spot_1
    - light.spot_2
    - light.spot_3
    - light.spot_4
    - light.spot_5
    - light.spot_6
    - light.spot_7
    - light.spot_8
    - light.spot_recess
    - light.spot_litter
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
In groups.yaml you don’t type groups: again.
Ah, so I need to place it in groups.yaml not configuration.yaml? Makes sense.
Thanks.
You can either delete the !include line from configuration.yaml, and put groups in configuration.yaml, or you can keep the !include line and have a groups.yaml. The latter is preferable IMHO.
Thanks Nick
