Creating image from data
Hi!
This might be XY problem here, but I want to be able to generate image with data from Home Assistant and make it available on local network.
(BMP, 8bit depth, 300x400 pixels)
For example I want to generate black and white image with analogue clock (optional) and temperature and weather data refreshed every minute or so.
Then I can just use simple download and display program running on ESP32 to display this image on E-Ink display refreshing every minute or so (made it already).
I’ve seen similar project but it needed assets to be on ESP32 and all formatting was done on ESP32.
What I want is to have all logic on HA and ESP32 being just simple E-INK display.
Hi @inobrevi
Have you already found a solution for this?
I have exactly the same plan, only for a 2.13” E-Ink display.
Thanks,
Chris
I did not :frowning:
