I was hoping my first post here was not going to be a question, but unfortunately I’m able to setup my first automations.
I’ve recently installed Home Assistant Core running in docker on an Odroid N2
The goal of my automations is to lower screens based on the position of the sun(azimuth). While taking into account cloud coverage (high coverage means the screens are not necessary) and wind speed (high wind speed could damage the screens).
The config validation in HA returns: Invalid config for [automation]: required key not provided @ data[‘trigger’][0][‘platform’]. Got None. (See /config/configuration.yaml, line 10).
I’ve validated that both files are valid YAML and scoured the forum for a solution without result.
Can someone please have a look and tell me what I’m missing?
My configuration:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# inclusions
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
# Text to speech
tts:
- platform: google_translate
# Weather sensor
- platform: openweathermap
api_key: APIKEY
forecast: true
monitored_conditions:
- weather
- temperature
- wind_speed
- humidity
- pressure
- clouds
- rain
- snow
- weather_code
- platform: buienradar
- stationname
- condition
- symbol
- humidity
- temperature
- feeltemperature
- windspeed
- pressure
- irradiance
My automations.yaml:
# Covers
# Eastside
- alias: "Lower sunscreens on Eastside of the house"
value_template: "{{ state_attr('sun.sun', 'azimuth') }}"
# Can be a positive or negative number
above: 55
condition:
condition: and
conditions:
# Prefix the first line of each condition configuration
# with a '-'' to enter multiple
- condition: numeric_state
entity_id: sensor.owm_cloud_coverage
below: 80
entity_id: sensor.owm_wind_speed
below: 13
service: cover.close_cover
entity_id:
- cover.overkapping
- cover.slaapkamer_1_links
- cover.slaapkamer_1_rechts
- cover.slaapkamer_2_groot
# Southside
- alias: "Lower sunscreens on Southside of the house"
above: 105
condition:
condition: and
conditions:
below: 80
below: 13
entity_id:
- cover.raam_bij_berging
- cover.woonkamer_hoekraam
- cover.slaapkamer_2_klein
- cover.raam_inloopkast
# Westside
- alias: "Lower sunscreens on Westside of the house"
above: 205
condition:
condition: and
conditions:
below: 80
below: 13
entity_id:
- cover.master_bedroom
- cover.woonkamer_links_hoek
- cover.woonkamer_schuifpui
- cover.woonkamer_keuken
# Northside
- alias: "Lower sunscreens on Northside of the house"
above: 280
condition:
condition: and
conditions:
below: 80
below: 13
entity_id: cover.vide
