Im trying to create a reusbale wled script which will have input variables such as effect, brightness, intensity, speed, color
here is my initial script, so please contribute to create awesome script, and later on to announce it as a blueprint.
alias: Wled set light
fields:
entity:
description: 'entity for light on service'
example: 'light.bathroom_wled'
speed:
description: 'speed of wled effect'
example: '100'
speed_entity:
description: 'entity for speed number wled'
example: 'number.wled_lr_below_tv_speed'
intensity:
description: 'intensity of wled effect'
example: '60'
intensity_entity:
description: 'entity for intensity number wled'
example: 'number.wled_lr_below_tv_intensity'
palette_entity:
description: 'sets wled palette'
example: 'select.wled_lr_below_tv_color_palette'
default: 'Default'
brightness_light:
description: 'Sets the brightness'
example: '100'
default: 100
rgb:
description: 'Sets the colors'
example: '100,242,100'
default: '100,100,100'
effect:
description: 'sets effect'
example: 'Twinkle'
default: 'Solid'
sequence:
# - choose:
# - conditions: '{{ if speed_entity is defined}}'
# sequence:
- service: light.turn_on
entity_id: "{{ entity }}"
brightness: "{{ brightness_light }}"
# rgb_color: >
# - '{{ rgb.split(",")[0].strip() | default(100, true) | int }}'
# - '{{ rgb.split(",")[1].strip() | default(50, true) | int }}'
# - '{{ rgb.split(",")[2].strip() | default(200, true) | int }}'
effect: "{{ effect }}"
- service: select.select_option
entity_id: "{{ palette_entity }}"
option: "{{ state_attr('palette_entity', 'options') | random }}"
- service: input_number.set_value
entity_id: "{{ speed_entity }}"
value: "{{ speed }}"
# - conditions: '{{ if intensity is defined}}'
# sequence:
entity_id: "{{ intensity_entity }}"
value: "{{ intensity }}"
What do you think? should I add something more here?
*This script is not tested, just wrote it from my head, so it’s probably broken
