Creating sensor template to convert a time in a string from HHMMSS into HH:MM:SS
I was trying to figure out how to convert a sensor input looking something like this: 123010 to: 12:30:10 but couldn´t find a solution.
What is the best way to do this?
Input “:” into the string or converting the sensor with as_timestamp?
Thank you in advance.
Maybe not the most elegant solution but you could adapt this:
{% set my_time = "123456" %}
{{ my_time[0:2]~":"~my_time[2:4]~":"~my_time[4:6] }}
Thank you, your solution worked!
I added my sensors input and it shows it like i want it to.
% set my_time = states('sensor.carport_wallbox_charge_end') %}
This might be a bit more elegant
{% set mytime = states('sensor.carport_wallbox_charge_end') %}
{{ strptime(mytime, '%H%M%S').strftime('%H:%M:%S') }}
Yet another way to do the same thing:
{% set my_time = "123010" %}
{{ my_time|regex_findall('..')|join(':') }}
In your case it would look like this:
{{ states('sensor.your_sensor')|regex_findall('..')|join(':') }}
Thank you for your reply.
I added your code to the sensor and it works fine.
