Hello friends, the following technical specifications:
Light switch - Zigbee
4x helper, input_boolean, for switching the lamps
4x helper group
to change the brightness
HACS-AddOns installed:
button-card, card-mod, layout-card, light-entity-card, mushroom-cards, slider-entity-row
The helpers are used to start a flow in Node_Red.
Unfortunately, the desired automation did not work in HA and the configuration was clearer in Node_Red.
Now to the actual problem:
I was looking for visually appealing cards and came across the HACS addon hue-like-light-cards
(GitHub - Gh61/lovelace-hue-like-light-card: This card provides a Hue-like way to control your lights in Home Assistant.)
bumped.
Unfortunately this add-on is not compatible with input_boolean switches, so I tried to create my own cards. And here the disaster begins.
After a lot of back and forth, I just can’t manage to change the background of the individual map sections and certainly not to make it bland, like in the hue-like-light-card.
Here is the current code of the card
type: entities
entities:
- entity: light.wz_deckenlicht_schneid_licht
icon: mdi:ceiling-light-multiple
- type: divider
- entity: input_boolean.1er_ceilinglight
state_color: true
- type: custom:slider-entity-row
entity: light.1er_deckenlicht_gruppe
full_row: true
- type: divider
- entity: input_boolean.2er_ceilinglight
entity: light.2er_deckenlicht_gruppe
full_row: true
- type: divider
- entity: input_boolean.3er_ceilinglight
entity: light.3er_deckenlicht_gruppe
full_row: true
- type: divider
- entity: input_boolean.5er_ceilinglight
entity: light.5er_deckenlicht_gruppe
full_row: true
I rebuilt the card what felt like 100 times, worked with the developer tools, tried to work with card_mod, but unfortunately nothing helped. I only managed to change the background of the element: - entity: input_boolean.1er_deckenlicht once, but not the entire map section (
state_color: true
full_row: true)
Could someone please help me with this problem or at least tell me an extension/add-on where I can create something like this?
The goal is to create individual groupings in the map, as seen in the image above - between the divider (could only post one image), use the input_boolean for switching and then use the respective light group for dimming. The background should also adapt, as with the Hue cards. Ideally, the background color should be visible across the entire element.
Thank you !
