Should we change the text in the repo so that the visitor now it is maintained? ![]()
This sounds promissing…
Could someone please give some more instruction how to setup the integration. I do not get it, since it seems to work different from other hacs integrations.
May I ask if someone could have a look at this Homebridge plugin, which stopped working too. https://github.com/himbeles/homebridge-kobold.
Maybe it can be fixed in the same way as the Home-Assistant integration. This would make a lot of people happy out there…
I already tried my best to find some kind of link to the fix presented here. However, I am no programmer…
Thanks in advance,
Jan
Hello @Cobi
Since latest HASS update 2025.11.1 this integration doesn’t work anymore.
Could you please allow issue creation on the github repo ?
e[33m2025-11-08 08:30:23.880 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to import_module with args ('custom_components.vorwerk.vacuum',) inside the event loop by custom integration 'vorwerk' at custom_components/vorwerk/__init__.py, line 106: await hass.config_entries.async_forward_entry_setups(entry, VORWERK_PLATFORMS) (offender: /usr/src/homeassistant/homeassistant/loader.py, line 1295: return importlib.import_module(f"{self.pkg_path}.{platform_name}")), please report it to the author of the 'vorwerk' custom integration
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#import_module
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 229, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 215, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 289, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 712, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 683, in run_forever
self._run_once()
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 2050, in _run_once
handle._run()
File "/usr/local/lib/python3.13/asyncio/events.py", line 89, in _run
self._context.run(self._callback, *self._args)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 906, in async_setup_locked
await self.async_setup(hass, integration=integration)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 672, in async_setup
await self.__async_setup_with_context(hass, integration)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 761, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/vorwerk/__init__.py", line 106, in async_setup_entry
e[0m
e[33m2025-11-08 08:30:23.913 WARNING (MainThread) [homeassistant.components.vacuum] The deprecated constant STATE_CLEANING was used from vorwerk. It will be removed in HA Core 2026.1. Use VacuumActivity.CLEANING instead, please report it to the author of the 'vorwerk' custom integratione[0m
e[33m2025-11-08 08:30:23.925 WARNING (MainThread) [homeassistant.components.vacuum] The deprecated constant STATE_DOCKED was used from vorwerk. It will be removed in HA Core 2026.1. Use VacuumActivity.DOCKED instead, please report it to the author of the 'vorwerk' custom integratione[0m
e[33m2025-11-08 08:30:23.935 WARNING (MainThread) [homeassistant.components.vacuum] The deprecated constant STATE_IDLE was used from vorwerk. It will be removed in HA Core 2026.1. Use VacuumActivity.IDLE instead, please report it to the author of the 'vorwerk' custom integratione[0m
e[33m2025-11-08 08:30:23.948 WARNING (MainThread) [homeassistant.components.vacuum] The deprecated constant STATE_PAUSED was used from vorwerk. It will be removed in HA Core 2026.1. Use VacuumActivity.PAUSED instead, please report it to the author of the 'vorwerk' custom integratione[0m
e[33m2025-11-08 08:30:23.970 WARNING (MainThread) [homeassistant.components.vacuum] The deprecated constant STATE_CLEANING was used from vorwerk. It will be removed in HA Core 2026.1. Use VacuumActivity.CLEANING instead, please report it to the author of the 'vorwerk' custom integratione[0m
e[33m2025-11-08 08:30:23.983 WARNING (MainThread) [homeassistant.components.vacuum] The deprecated constant STATE_DOCKED was used from vorwerk. It will be removed in HA Core 2026.1. Use VacuumActivity.DOCKED instead, please report it to the author of the 'vorwerk' custom integratione[0m
e[33m2025-11-08 08:30:23.995 WARNING (MainThread) [homeassistant.components.vacuum] The deprecated constant STATE_IDLE was used from vorwerk. It will be removed in HA Core 2026.1. Use VacuumActivity.IDLE instead, please report it to the author of the 'vorwerk' custom integratione[0m
e[33m2025-11-08 08:30:24.006 WARNING (MainThread) [homeassistant.components.vacuum] The deprecated constant STATE_PAUSED was used from vorwerk. It will be removed in HA Core 2026.1. Use VacuumActivity.PAUSED instead, please report it to the author of the 'vorwerk' custom integratione[0m
e[31m2025-11-08 08:30:24.007 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry <snip-email> for vorwerk
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2589, in async_forward_entry_setups
await integration.async_get_platforms(platforms)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1176, in async_get_platforms
import_future.result()
File "/usr/src/homeassistant/homeassistant/loader.py", line 1164, in async_get_platforms
platforms.update(self._load_platforms(platform_names))
File "/usr/src/homeassistant/homeassistant/loader.py", line 1089, in _load_platforms
platform_name: self._load_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1263, in _load_platform
cache[full_name] = self._import_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1295, in _import_platform
File "/usr/src/homeassistant/homeassistant/util/loop.py", line 201, in protected_loop_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.13/importlib/__init__.py", line 88, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 1027, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/config/custom_components/vorwerk/vacuum.py", line 11, in <module>
from homeassistant.components.vacuum import (
...<14 lines>...
ImportError: cannot import name 'SUPPORT_BATTERY' from 'homeassistant.components.vacuum' (/usr/src/homeassistant/homeassistant/components/vacuum/__init__.py)e[0m
Same issue here… ![]()
Change imports (in vacuum.py):
ATTR_STATUS,
StateVacuumEntity,
VacuumEntityFeature,
change feature flags (also in vacuum.py):
SUPPORT_VORWERK = (
VacuumEntityFeature.PAUSE
| VacuumEntityFeature.RETURN_HOME
| VacuumEntityFeature.STOP
| VacuumEntityFeature.START
| VacuumEntityFeature.CLEAN_SPOT
| VacuumEntityFeature.STATE
| VacuumEntityFeature.LOCATE
don’t forget to save and restart ![]()
This worked for me as well
Hi @FKi
Thanks for tips.
But some actions failed like Start and Go back to dock
vacuum/start. name 'STATE_IDLE' is not defined
vacuum/return_to_base. name 'STATE_CLEANING' is not defined
Did you have some fixes ? Maybe a fork to work on.
Hello there,
Someone ( @bndtblds ) create a full working fork : GitHub - bndtblds/homeassistant-vorwerk: Home assistant integration to control Vorwerk VR Vacuum cleaners
Thanks for the hin!
I got this error message:
- Einrichtungsfehler, wird erneut versucht: Unable to communicate with robot
Any idears how I can solve this?
Thanks and regards
Status now ? @bndtblds or @cobirnm repo ? Thanks a lot
Both are working at the moment as far as I know
I’m using this fork right now, seems to be maintained well:
bndtblds
