Cretate a device_tracker from a binary_sensor is it possible?
I have a binary_sensor that I use as a presence detector (on home off not_home), I wish to transform it into a device_tracker, is it possible?
I don’t know if you can change it to a true device_tracker but you can make it read as ‘home’ or ‘away’ by changing the ‘device_class:’
EDIT: Just re-read your post. You already have it set up like that. Never mind…
I guess I’m not exactly sure why you would want to, but you could do it using my custom Composite Device Tracker.
I recently did something like this for the bluetooth Monitor baysian sensor. Look up the device_tracker.see service. When I get home I can post my automation example if needed.
I am in the same boat.
I use the BLE monitor tool by @andrewjfreyer which provides a confidence level for presence based upon bluetooth.
However the new person component only works with device tracker entities, so I cant use my Bluetooth presence fto inform a new person entity.
I did it using mqtt device tracker + a simple automation that sends “home” / “not_home” mqtt message to the tracker’s topic whenever sensor’s state changes (not the most elegant but works great).
Yep, I saw your component after posting. Testing it right now, seems working fine. Thanks
My same problem
I also originally combined multiple device_trackers per person using automations and the device_tracker.see service. Then I turned that into the custom composite device_tracker platform. :slight_smile:
FWIW, my custom composite device tracker also accepts BLE-based device_trackers.
@phileep just chiming in to say that monitor does have device_tracker support, implemented just after the person component was released. See the FAQ here.
problem is when you have more then one monitor instance you have multiple device_tracker (one for each monitor instance) but should be just one: for the phone tracked
The person component can handle multiple device trackers, so that’s what a lot of folks have done. Another option is to use the device_tracker.see service as described here and here.
There are many ways to skin this particular cat.
Ahhh, ok did not know that, I will investigate how to combine yours (which are just home not home) together with gps based trackers
