As the title suggests, chrimereports has a specific requirement for “requests” module.
The exact error is:
crimereports 1.0.0 has requirement requests==2.12.4, but you’ll have requests 2.18.4 which is incompatible.
Any ideas on how to install the older version? How do I know that nothing else in Hass has a dependency on the newer version?
fabaff
(Fabian Affolter)
June 1, 2018, 7:03am
2
This should be fixed upstream.
opened 07:03AM - 01 Jun 18 UTC
closed 06:24PM - 18 Feb 19 UTC
requests is pinned to a specific release (install_requires=['requests==2.12.4'],). This avoid the installation in Home Assistant.
Please remove the pinning.
Any update on this?
Still getting the following error: “crimereports 1.0.0 has requirement requests==2.12.4, but you’ll have requests 2.20.0 which is incompatible.”
fabaff
(Fabian Affolter)
November 3, 2018, 8:32am
4
It’s an issue in the module which we use.
Will this ever get fixed?
crimereports 1.0.0 has requirement requests==2.12.4, but you’ll have requests 2.20.1 which is incompatible.
fabaff
(Fabian Affolter)
February 18, 2019, 6:28pm
6
We are still waiting for a new crimereports release.
Has anyone made the request? I would if I knew how, i’m just not technical and not sure what to request. Until this is done, can we take the component out of the library as people are using it thinking it’s working? You only get an error when trying to upgrade.
