Critical iOS notification with message template
I’m trying to edit an existing iOS notification automation that currently works and send me my thermostats temperature when it is out of range. I’m currently using the below action in my automation:
service: notify.mobile_app_****_iphone
 message: "Temperature Out of Range: {{ states('sensor.my_ecobee_temperature') }}"
 title: “Temperature Out of Range”
I’m trying to update this to be a “critical” notification so I am sure to get the notification on CarPlay and when in do not disturb.
I’m trying to add to the action with the below script:
 push:
  sound:
   critical: 1
   volume: 0
The problem is when I try to test this I get the following pop up:
Error running action
extra keys not allowed @ data[‘push’]. Got None
Anyone have any advice on this?
https://community.home-assistant.io/t/how-to-help-us-help-you-or-how-to-ask-a-good-question/114371#oneone-format-it-properly-16
Or the </> button, not the button.
Fixed, thanks
It needs an extra data: key.
  - service: notify.mobile_app_****_iphone
      title: "Temperature Out of Range"
        push:
          sound:
            critical: 1
            volume: 0 # this should be 1 if you want to hear it
Wow an easy one. Thank you that worked!
for me this doesn’t work if it’s nested under push, but this does:
        sound:
          critical: 1
          volume: 1
