Kreptki
(Kreptki)
June 15, 2021, 1:07pm
1
Found this thread which started me on this path:
https://community.home-assistant.io/t/bitcoin-monitoring-with-home-assistant/199100
I am not using the bitcoin sensor, instead i created a statistics sensor that I want to monitor. This sensor returns € x.xx or € -x.xx (positive/negative) but i cannot seem to get the light to work. I know the script from @Krisseck (thank you sir) works as i can run it successfully.
My automation script:
- alias: PNL drop
value_template: '{% if (states.sensor.profitloss_status.from_state.state | float - states.sensor.profitloss_status.to_state.state | float) / states.sensor.profitloss_status.to_state.state | float < -0.05 %}true{%endif %}'
service: script.turn_on
entity_id: script.flash_light_red
- alias: PNL increase
value_template: '{% if (states.sensor.profitloss_status.from_state.state | float - states.sensor.sensor.profitloss_status.to_state.state | float) / states.sensor.profitloss_status.to_state.state | float > 0.05 %}true{%endif %}'
entity_id: script.flash_light_green
Any input is greatly appreciated.
Troon
(Troon)
June 15, 2021, 1:24pm
2
See if this works. It’d be fairly simple to convert them into a single automation, but let’s check it works first. Triggers off any change to the sensor, then works out whether to proceed with the flashing light.
- alias: PNL drop
- platform: state
entity_id: sensor.profitloss_status
condition:
- condition: template
value_template: >-
{% set pl_from = trigger.from_state.state|float %}
{% set pl_to = trigger.to_state.state|float %}
{{ (pl_from - pl_to) / pl_to < -0.05 }}
- platform: state
condition:
value_template: >-
{{ (pl_from - pl_to) / pl_to > 0.05 }}
Notes:
I don’t think you can use the from_state and to_state in the trigger like you were trying to, but happy to be proven wrong. Docs .
It’s better to use states('entity_id') than states.entity_id.state. See warning here .
You had an extra sensor. in your increase template.
Kreptki
(Kreptki)
June 15, 2021, 1:53pm
3
@Troon It works!
I am always humbled at this community and its oracles, I have much to learn yet but your help will help immensely.
Thank you so much!
Troon
(Troon)
June 15, 2021, 2:03pm
4
Here’s a combined version (totally untested). The condition looks for an absolute value out of your formula greater than 0.05, which also includes less than -0.05 — then the choose in the action (docs ) decides which colour to flash depending on whether from is larger or smaller than to. It’s possible I have the colours the wrong way around: not sure I’m following your calculation correctly.
- alias: PNL indicator
- platform: state
condition:
value_template: >-
{{ ((pl_from - pl_to) / pl_to)|abs > 0.05 }}
- choose:
- conditions: "{{ trigger.from_state.state|float > trigger.to_state.state|float }}"
sequence:
- service: script.turn_on
- conditions: "{{ trigger.from_state.state|float < trigger.to_state.state|float }}"
sequence:
Kreptki
(Kreptki)
June 15, 2021, 2:10pm
5
The combined also works, i reversed the colors. Now my “Lambo” light works perfectly.
thank you
Troon
(Troon)
June 15, 2021, 2:11pm
6
You’re welcome. Just imagining your house lighting up like the USS Enterprise on red alert every time Elon drops a negative tweet…
Kreptki
(Kreptki)
June 15, 2021, 2:15pm
7
Don’t tempt me… might get too much aggro from the girlfriend YOLO
