I’m running Raspbian bookworm and HA Core in a venv.
Starting HA 2024.4 Python 3.12 is needed, I am now running Python 3.11.6.
Having tried the upgrade a month ago already but failing, I reverted back to HA 2023.3.1 with Python 3.11.6.
Today I wanted to retry the upgrade, but failed again. This is what happened (followed the guide Upgrading HomeAssistant Core in a Python VE - #9 by romanovj):
- I downloaded the Python 3.12.2 tgz from the official source
./configure --enable-optimizationsmake -j4sudo make altinstall
=>python3.12 --versiontells me:Python 3.12.2sudo mv /srv/homeassistant /srv/homeassistant-oldsudo mkdir /srv/homeassistantsudo python3.12 -m venv /srv/homeassistant- (as homeassistant in venv)
pip3 install homeassistant
=> all dependencies build and install successfully
=> rust compiler for building: (installed using rustup)
stable-arm-unknown-linux-gnueabihf (default)
rustc 1.77.2 (25ef9e3d8 2024-04-09)
=> running hass returns the following:
File "/srv/homeassistant/bin/hass", line 8, in <module>
sys.exit(main())
File "/srv/homeassistant/lib/python3.12/site-packages/homeassistant/__main__.py", line 174, in main
args = get_arguments()
File "/srv/homeassistant/lib/python3.12/site-packages/homeassistant/__main__.py", line 82, in get_arguments
from . import config as config_util
File "/srv/homeassistant/lib/python3.12/site-packages/homeassistant/config.py", line 27, in <module>
from . import auth
File "/srv/homeassistant/lib/python3.12/site-packages/homeassistant/auth/__init__.py", line 13, in <module>
import jwt
File "/srv/homeassistant/lib/python3.12/site-packages/jwt/__init__.py", line 1, in <module>
from .api_jwk import PyJWK, PyJWKSet
File "/srv/homeassistant/lib/python3.12/site-packages/jwt/api_jwk.py", line 7, in <module>
from .algorithms import get_default_algorithms, has_crypto, requires_cryptography
File "/srv/homeassistant/lib/python3.12/site-packages/jwt/algorithms.py", line 12, in <module>
from .utils import (
File "/srv/homeassistant/lib/python3.12/site-packages/jwt/utils.py", line 7, in <module>
from cryptography.hazmat.primitives.asymmetric.ec import EllipticCurve
File "/srv/homeassistant/lib/python3.12/site-packages/cryptography/hazmat/primitives/asymmetric/ec.py", line 11, in <module>
from cryptography.hazmat._oid import ObjectIdentifier
File "/srv/homeassistant/lib/python3.12/site-packages/cryptography/hazmat/_oid.py", line 7, in <module>
from cryptography.hazmat.bindings._rust import (
ImportError: /srv/homeassistant/lib/python3.12/site-packages/cryptography/hazmat/bindings/_rust.cpython-312-arm-linux-gnueabihf.so: undefined symbol: EVP_idea_cbc, version OPENSSL_3.0.0
=> openssl version tells me:
OpenSSL 3.0.11 19 Sep 2023 (Library: OpenSSL 3.0.11 19 Sep 2023)
→ newest version from apt repository
What can I do to resolve this issue? It seems the mentioned .so file does not contain the symbol (I checked with nm -gD), so maybe the wrong openssl is used? I just installed the official packaged version via sudo apt install openssl.
(I’m glad I mv-ed the old directory somewhere else, as I can easily restore the old running version in no time)
