CS:GO Game State Intagration
Ok games and coders out there, you will probably already know what im talking about. Valve recently opened up CS:GO so that certain events could be read by other programs when triggered. What would be great is for someone who can code better than me, to create a frame work for people to modify your code to use home assistants api to control lights based on events in game. If anyone out there is able to do this that would be amazing. Its beyond me at this stage im affraid.
Here is valves documentation on game state integration and here is an example in node.js that controlled hue lights.
Note: I moved this to feature requests from configuration as i was informed it should be here instead.
This should most likely be in the Feature Request section since it’s not a problem with your configuration.
