CS2531 Zigbe2mqtt not able to setup
Hey everybody,
im currently trying to “listen” to my Hue devices at home (especially the smart buttons) using a CS2531 USB dongle. I am running HA in a python virtual machine linked to systemd to autostart. The zigbee2mqtt is running on the same device (Pi) (later also with systemd, but currently not).
I installed the Zigbee2mqtt component following this guide:
Afterward, I followed the zigbee2mqtt guide for Home Assistant:
However, I do have problems understanding the part that has to be done in HA. Where do I define the devices that should be listend to? Or is this done by the zigbee2mqtt?
My configuration.yaml file of zigbe2mqtt looks like this:
# Home Assistant integration (MQTT discovery)
homeassistant: true
# allow new devices to join
permit_join: true
# MQTT settings
mqtt:
  # MQTT base topic for zigbee2mqtt MQTT messages
  base_topic: zigbee2mqtt
  # MQTT server URL
  server: 'mqtt://localhost'
  # MQTT server authentication, uncomment if required:
  # user: my_user
  # password: my_password
# Serial settings
serial:
  # Location of CC2531 USB sniffer
  port: /dev/ttyACM0
Info: The zigbee2mqtt is running on the pi as HA
My logs look like this:
> [email protected] start /opt/zigbee2mqtt
> node index.js
zigbee2mqtt:info  2020-02-17 19:58:45: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2020-02-17.19-58-45' filename: log.txt
zigbee2mqtt:info  2020-02-17 19:58:46: Starting zigbee2mqtt version 1.10.0 (commit #8df6be8)
zigbee2mqtt:info  2020-02-17 19:58:46: Starting zigbee-herdsman...
zigbee2mqtt:info  2020-02-17 19:58:48: zigbee-herdsman started
zigbee2mqtt:info  2020-02-17 19:58:48: Coordinator firmware version: '{"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190608}}'
zigbee2mqtt:info  2020-02-17 19:58:48: Currently 0 devices are joined:
zigbee2mqtt:warn  2020-02-17 19:58:48: `permit_join` set to  `true` in configuration.yaml.
zigbee2mqtt:warn  2020-02-17 19:58:48: Allowing new devices to join.
zigbee2mqtt:warn  2020-02-17 19:58:48: Set `permit_join` to `false` once you joined all devices.
zigbee2mqtt:info  2020-02-17 19:58:48: Zigbee: allowing new devices to join.
zigbee2mqtt:info  2020-02-17 19:58:48: Connecting to MQTT server at mqtt://localhost
zigbee2mqtt:info  2020-02-17 19:58:48: Connected to MQTT server
zigbee2mqtt:info  2020-02-17 19:58:48: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
zigbee2mqtt:info  2020-02-17 19:58:48: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"version":"1.10.0","commit":"8df6be8","coordinator":{"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190608}},"log_level":"info","permit_join":true}'
Given, that I understand it correctly this is telling me, that I should set permit_join = true which I have.
So, how do I add devices to zigbee2mqtt and then send publish a mqtt message to HA?
I really struggle with this whole exercise :frowning:
I hope somebody can help me figure out what I have to do in order to make this working. Thank you!
Cheers,
Christian
put your smart button in pairing mode
Once paired your devices should be autodiscovered by Home Assistant (via mqtt autodiscover).
Check zigbe2mqtt logs while pairing and then search the sensor at the states page.
You search for your device here :
and follow the instructions for your device. Every manufacturer (and even device) has it own way to pair.
